255/35/18 Pirelli's going on next week!!
Been a while and as you all know, I like to change m y wheels on the regular.
Anyway, i picked up a set of 255/35/18 Pirelli Pzeros which I plan on throwing onto a set of 18" x 8.0" Legend wheels which are currently getting the bronze color powdercoating treatment. I'll post pics of the tires tomorrow and the wheels later this week. Let me tell you, these 255 tires a friggin WIDE. I don't think I will rub either with the 48mm offset.
Here's how my car is riding now with the 19" and 20" setup (getting kind tired of the ride comfort).
Whats up with RDX owners?
Jesus, 255. I cant wait to see them on there.
yeah, and i had a set of Legend GT 18" x 8.0" / 48mm offset wheels refinished to a dark bronze powdercoat with matte clearcoat. Tomorrow I'll get everything installed hopefully. Here are some pics of the tires, they are so wide, I hope they don't rub. I also have some pics of the 3 piec ewheel parts I'm using to make some sick one off wheels for the new 4G TL I'm getting and the wife's pilot.
depending on your offset, it should be fine, I had 245's on before and they cleared the fender, howeever, I had a 52mm offset.
Here are some pics of the wheels getting custom finished. The first pics are of the wheels in raw aluminum, just drying out of the stripper. Then the silver basecoat is applied and then they went into the oven. I saw the final color, and man do they look sweet, I was just so excited, I forgot to shoot them. Tomorrow they will be on the car with pics!!!
wow, 9" is pretty wide, but the offset is very good. Just measure your clearance with your current tire and add the appropriate tire size increase.
Technically, the wider wheel shouldn't make the tire any wider, but it will angle the sidewall to give it that stock car look or stretched tire look.
I ♡ PEK PEK
they fit perfect, no rubbing and no peeling out, just hooking up and going. I can rip the tires loose if I pop the clutch from a stand still only. But these things handle great, I took a turn at 60 mph where I only was able to get up to 40 soemthing before. I love em!
MMmmmm they look nice.
Looks great. Makes me want to try 255s on my 2gTL
Any updates on this tire size? Rubbing or issues?
Is this size 255/35/18 specific to ONLY Pirelli p zero??
How does one get the actual tire size vs just the stated #s on tire? Like actual
Researching I saw it seems pirrelis run a touch small? Please confirm
I have run 255/35/18 tires for years now. For fitment you have to consider wheel specs including offsets, alignment settings, how stiff car is sprung, how low car is, etc.
That size is universal, not Pirelli specific. You can check tire specs on www.tirerack.com. Not all 255/35/18 tires are exactly same. One set could rub when another set does not.
There is a wheel offset and tire size calculator at www.1010tires.com.
You could just run 245/40/18 Bridgestone RE-71R tires in 200 tread wear and have more grip than any other 255/35/18 tire besides 255 RE-71R.
Ronjon has not posted on this site for years.
That size is universal, not Pirelli specific. You can check tire specs on Tire Rack - Your performance experts for tires and wheels. Not all 255/35/18 tires are exactly same. One set could rub when another set does not.
There is a wheel offset and tire size calculator at 1010TIRES.COMŽ ? Tires and Wheels Online Authority..
