Fan stays on when I turn the car off
Old 05-08-2011, 07:40 PM
rsamano's Avatar
I have a 07 CL with 140K miles. The transmission when out about 18 months ago. When I drive the car in summer (like now) the car's fan stays on for a really long time. I drove it about 10 miles and the car's fan stayed on for over 15 mins, what is causing it to get so hot so fast?
rsamano
Old 05-08-2011, 08:08 PM
Be Strong AND Courageous!
DarkSithCL's Avatar
rsamano
this is my list... I have a 2001 CL S
is it actually running hot or is the fan thermostat malfunctioning (unlikely but possible)
bad radiator cap (best bet)
bad water pump,
thermostat
a small radiator leak
a small hose leak
poor coolant mixture
... also see if your coolant reservoir has anything in it... it should always have a small amount of coolant too...
this is in no particular order after the cap
hope this helps!
Old 05-11-2011, 08:03 AM
Oakroadsteve's Avatar
I had the same issue and the water in the reservoir tank was low..
Old 05-11-2011, 08:38 AM
Lone Wolf
brian6speed's Avatar
you have an 07 CL
02-25-2020 09:57 AM
handsom-hustla
11-13-2015 05:04 PM
aces2412
3G MDX (2014-2020)
09-07-2015 08:40 PM
NSolace
09-03-2015 08:02 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: Fan stays on when I turn the car off
