2G CL Frequently Asked Questions No New Threads Please.
DIY for my interior issue
Old 02-25-2007, 10:36 PM
Misdby1's Avatar
Well, better late that never on the DIY. This is the same post as in my "interior issue" thread, I didn't want it to get lost.
First, research how to remove the door panel. The corner speaker is held on with clips, they just pop out and can be wiggled out.
Hint to removing the door handle. One you take out the only screw, slide the whole assembly to the right and then pull out.
Once your in, you'll have to remove the retainer for the door handle bar. Real easy, it just pushes off and rotates away. Just lift the bar out and push it inside the door.
There are (2) screws that hold on the panel and 4 or 5 clips. They are easy to remove and more durable than the domestic car panel clips.
This clip was the hardest to undo. I recommend rotating the entire door panel upside down and then undoing the clip.
The inside of the door panel. There are a BUNCH of screws holding on the armrest but thankfully they aren't long winded.
Once you get the armrest off, there are two screws holding on the Window control cluster. You'll need to remove the power mirror switch to get to one of them. the switch is removed by wedging a screwdriver between the housing and the underside of the armrest in order to push the metal tabs down. DON'T FORCE IT. It will come out with a little persuasion.
(the pictures I took were blurry and i'm not tearing apart the car again.)
Here is the problem area:
Gorilla glue or Rhino glue - pick your african mammal - just make sure the bottle says for use on foam and plastics. A lot of the glues won't adhere to either. (thank you to my mother for enlightening me to that little fact) I bought my glue at Walmart for $3 and a pack of 16 spring loaded clips for $4.
Here is my setup. I used a paint stirrerererrerreerrer against the finished side of the door handle to maintain an even pressure and not create little dimples where the clips were.
By the end of the NASCAR race it was set. Here is the result:
Before:
After:
I also fixed this part of the door handle while I was at it.
Hope this helps the next person! Thanks for playing.
The following 2 users liked this post by Misdby1:
AMart83 (09-06-2014), Kabayo (07-18-2013)
Old 02-25-2007, 10:46 PM
Don't Mess With Texas
cltypeSLOW's Avatar
awesome write up, id be interested in an update in a month or so to see how its holding up. my door has the same prob on both sides
Old 02-27-2007, 07:37 PM
MinTS's Avatar
Awesome job...i'd be too scared to mess something like that up.
Old 02-27-2007, 08:46 PM
GreenMonster's Avatar
Sweet... Great Reference...
I'll let it stay here in th general forum for a couple of days, but this will be a nice addition to the threads in the FAQ forum...
Great job !!
Old 02-28-2007, 08:45 AM
CLS 6MT Navi
123456SPEED's Avatar
Good job.
Is that a pack of Tylenol on the ground??
You didn't mention that was needed!
Old 02-28-2007, 08:55 PM
I'm a Vagiterian.
All Mine's Avatar
Also note- Do NOT step on Blackberry.
Old 02-28-2007, 09:11 PM
wants mods
xBlur's Avatar
Awesome write up. I may need to do this soon, both doors are getting bad.
Old 02-28-2007, 10:02 PM
I'm here in spirit...
Lord Helmet's Avatar
You mean the one laying face down on the concrete?
Good write-up.
Old 02-28-2007, 10:11 PM
SOLD: 03 SSM CLS Auto
gaping46and2's Avatar
That glue will probably not come apart. It just needs to set overnight to harden. Only thing about Gorilla glue that I've noticed is it expands while it dries, but those clamps look like they worked good.
A little off topic: What exactly is that white plastic lining in the doors, is that some sort of sound damping or water proofing?
Old 02-28-2007, 10:24 PM
Misdby1's Avatar
Originally Posted by 123456SPEED
Good job.
No, the pain relief for this project is in the fridge!
You can use this one as a hockey puck for all i care, I have nothing nice to say about blackberry.
Yeah, it does foam. If you use it sparingly and shove the tip of the bottle far enough down, overglue isn't an issue. I barely used any of that little bottle.
The plastic is a vapor barrier, that's all. It just keeps the condesation out of the cabin. Like wrapping a building in Tyvek. What really puzzled me was the seemingly usless hollow box to the lower right of the inside of the panel and matching cut out in the door. It was like it had a purpose at some point, or maybe a carry over from a different model. The only thing it would work for is a stash...
Old 02-28-2007, 10:35 PM
Yeah, I think the rear panels have a similar cut out and hollow box. I guess it's just some kind of suport for the door panel, so it's not a single layer? Can that vapor barrier be removed and replaced easily? It looks like it's glued in pretty good. Asking because I'm thinking of adding some sound dampener to the doors sometime in the future, and that stuff is kinda in the way.
Old 02-28-2007, 10:57 PM
o1s
o1s's Avatar
that plastic is close to impossible to get loose from the door without stretching it or tearing it. i also don't remember seeing that little plastic piece on my door panel when i had to replace my window regulator.
RichTypeS (08-17-2014)
Old 02-28-2007, 11:10 PM
I'm a Vagiterian.
All Mine's Avatar
Yeah, the one I had for work sucked too, but I wouldn't want to pay to replace mine.
Damn, good idea.
Old 02-28-2007, 11:11 PM
I'm a Vagiterian.
All Mine's Avatar
The face slides into the holster.
Old 03-04-2007, 12:05 AM
thAviEtbOi 37's Avatar
Nice...I actually did something similar to this but I used tape and chopsticks. Works fine for me when I used Gorilla glue, been over a year now.
Old 03-04-2007, 03:13 PM
Unregistered user
LIPPSTUH's Avatar
man, i can see it coming off slowly on my driver door too =[ i guess i should bookmark this.
Old 03-04-2007, 04:46 PM
Cleanest white cl in LA``
mehhh's Avatar
LMAO. pick your african mammal.
Old 03-04-2007, 05:17 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Great job.
Old 03-04-2007, 10:27 PM
bringin lead
FirePR2002's Avatar
Nice write-up!
Old 03-10-2007, 01:03 PM
MP90 uninstalled
jproy's Avatar
still laughing over the pick your African mammal comment
Old 05-02-2007, 07:38 AM
Shogun Assassin
fahoumh's Avatar
From what I understood, the glue is used to hold the armrest's shape so it no longer sticks out? Sorry for the stupid question.
Old 05-02-2007, 10:57 AM
ridin slow'n'low
smokendsm's Avatar
Work looks top notch! How is it holding up after 2 months?
Old 05-02-2007, 01:00 PM
Shogun Assassin
fahoumh's Avatar
NM, I figured it out....
Old 05-02-2007, 02:48 PM
Misdby1's Avatar
It looks just like the pictures i posted! It's holding up wonderfully!
Old 05-02-2007, 02:56 PM
ridin slow'n'low
smokendsm's Avatar
Definitely doing this as soon as I have some time!
Old 05-10-2007, 12:27 AM
corpsdawg's Avatar
I'm not getting it.
Okay, so i cant exactly figure out what the glue is for. Do you just apply it onto the problem side and wait for it to dry then use the clamps and stick to keep its shape? I'm not exactly sure of the procedure. Help?
Old 06-20-2007, 10:31 PM
woooo!!
subtledreamer's Avatar
Just did this today... they look as good as NEW now!
Thanks a lot for the DIY & pictures Misdby!!
Old 06-21-2007, 10:29 AM
Misdby1's Avatar
Sorry for the seriously late response. Yes, you apply the glue between the foam on the inside of the vinyl and the plastic support of the arm rest. For uniform adhesion and no waves in your armrest, use something flat that will spread out the force of the clamps evenly (i.e. a paint stir stick). If you need anymore help or information, please email me personally misdby1@gmail.com.
I hope you've figured it out.
By the way, after 5 months, it still looks great.
Old 07-07-2007, 12:52 PM
B A N N E D
vzuptnguyen's Avatar
wow great right up! i didnt realize more people had this issue as well. i just thought my friend did it from standing on it. haha...that probably jerked it out more though.
for mine, it actually peels at the ashtray bezel on the armrest and as well as the door handle on the inside. i wonder if i can fix that as well.
Old 03-01-2008, 12:52 PM
NighthawkBlack's Avatar
Nice Job! Dealer replaced mine on the rear driver side under warranty, Problem is the color doesnt match. Nothing I can do now but it is happening to others now. I will do it to them. Are there different types of gorilla glue or only one? Thanks
Old 03-03-2008, 11:03 AM
Misdby1's Avatar
There are different types of "Gorilla glue". I think I used Rhino or something. The important thing is you use a type of glue that doesn't eat foam. If the used says it can be used on foam then you'll be safe.
BTW - no break down yet.
Old 03-10-2008, 03:05 PM
Misdby1's Avatar
After 1 year... (okay 2 weeks shy of one year)
Old 03-14-2008, 08:59 PM
Eurotrash
Tosh's Avatar
I've bookmarked this. That's a really nice job. I got dealer to replace both sides of mine while under warranty, but they're starting to separate again.
I don't think you have to remove the tweeter housing to get the door panel off, as I don't remember doing that. Could someone confirm?
Old 03-18-2008, 05:51 PM
correct.
Old 07-24-2008, 05:15 PM
Exquisite One
2000tlrjm's Avatar
Very nice write-up. A couple of my doors are doing the same thing, so I'm sure this will definitely help sometime in the VERY near future.
It seems like this issue is another one of those "usual" issues as with any Honda/Acura. I used to have a '96 Accord EX and the temperature control knob for the climate control broke three different times. LOL, oh well, I guess there's going to be small issues when you make the car itself basically impeccable.
I love Honda/Acura for so many different reasons!!!!!
Old 08-01-2008, 11:51 PM
kassemwy1223's Avatar
As soon as I have time I plan to take before and after pics. I will be doing this because mine is bad! It's starting to hang low and loosely... it's bad! Bet.... anyone know anything about the driver power seat
up and down works, front and back works, not recline doesn't adjust the back in a sitting up position or laying back position. I hear the motor it makes a sound then does a little "click sound and stops" it won't work..... grrrr also I ordered a window regulator from a member acurazine, I will be doing the project too.... well Thanks for your time!! Have a good and safe weekend!
Old 08-15-2008, 01:02 AM
3rd Gear
jazzmv's Avatar
I just got my 1st CL (03) and I read on the other forum (1st Gen) about changing the light in the dash to blue, does anyone knows if the same applies to the 2nd Gen? I am worry only because of the digital panel, any suggestions???
Old 01-27-2010, 06:49 PM
cu0ngsayz's Avatar
sorry for bringing this thread back up but good write-up.. i just got a cl-p recently and have this problem too... mine looks bad
Old 04-04-2010, 08:20 PM
bcart180's Avatar
great write-up!
i fixed my door handle today!
Old 04-05-2010, 01:02 AM
cu0ngsayz's Avatar
damn... wanting to go about doing this but just cant really find the right time to do this
Quick Reply: DIY for my interior issue
