Woodgrain Upgrades! (Plus Steering Wheel How-To)
Ok, thanks the the help I got from the people in this thread things were a lot easier. My new steering wheel came with instructions but if yours does not, you might want to download the instructions found in that thread. Here are some pictures and some notes from my install to hopefully help others out...
Before install...
The horn and the SRS plug are beneath the steering wheel and look like this...
Now the instructions say to disconnect the battery and wait 3 minutes. This might have to do with the SRS computer. I don't have the code to my radio (for now) so I left it connected. However, after everything was done, my SRS light it on and does not go off. As soon as I get my code, I will disconnect the battery and see if it gets rid of the SRS light.
There is a Torx screw on each side holding the airbag in place. It takes a T-30 bit. I used an extension on my screwdriver to get a little more torque...
My steering wheel was new and came with two new Torx screws to use. If yours is used, you will probably need to reuse them so don't toss them like the instructions say. I imagine they only do this since it is what holds the airbag and the new screws have what appears to be a threadlock paste on them that, once broken, is not considered adequate by "safety standards". Here is what things look like with the airbag removed...
Now I don't know about yours but my steering wheel did NOT want to come off. It was on there GOOD! First, the center bolt was really tough. My instructions said it was 19mm but it clearly is not. It is 14mm. I used an impact wrench to make the job a hell of a lot easier and faster. I then had to use a gear puller to pry the steering wheel off. Now if you do this, the center screw part of the gear puller is going to be pushing into the hole. DO NOT DO THIS unless you have something for it to push against! You don't want to damage your threads inside! I found that a 5/16" washer was a perfect fit in there for the piece to push down against.
If you do any work on cars at all, you have a torque wrench around. The instructions say to torque the center bolt to 36 ft-lbs. Here is the final install of my new woodgrain parts...
Before install...
Dunno man! Because I give a sh!t about my car and usually that's only CLS owners? hehe Ok, so I'm slamming CL owners and I am one. I could have gotten a CLS but I got a good deal on this one and it is just my daily driver. I like the woodgrain interior more as well. Just my preference. This is what I drive when I have the urge to go fast. ...
Thanks for the comments. I know its not the best "write up" in the world but I always feel better seeing pics before I try to do something. Hope it helps someone else out and make the job easier.
nice, i have the wood grain accents too... im waiting to install the dash vents and gauge bezel, looks like you just need that to complete the look.
oh and i need the steering wheel too, lol.
did you clean the vents before putting the woodgrain on it? i know your supposed to use a solution to get any armor all off.
As for cleaning the vents, YES! A must! I cleaned them fairly well with a little soap and water and made sure they were dry. Nope! Not good enough. Damn sticky stuff on the back of the accents did not want to stick. I didn't have any alcohol around so I squirted a bit of brake cleaner on a rag and went over the areas that would be in contact with the tape. Brake cleaner > ALL! hehehe
I'm here in spirit...
Damn, I must admit, that looks I have always liked the woodgrain in the CL-p on ebony int. I think it looks a lot nicer than the black marble stuff. Nice job man. Keep up the good work.
Thanks man! I appreciate all the kind words! I probably won't do any performance mods especially given it is a CL and the extended warranty but I do have some more appearance mods in the works.
https://acurazine.com/forums/showthr...ht=reset+light
Instead of using a bent paperclip, it is easier to just use a wire. Also, just to make it clearer, the yellow plug with the two green wires is not the one you are jumping. It is the smaller plug above it.
This didn't read correctly to me the first time I read it but after reading again, it made more sense. Just thought I would point this out in case someone else doesn't catch it. Easily reset the SRS light myself. Quick and painless. In fact, it is so much easier than pulling the battery that I would recommend doing it this way anyway!
Hey thanks!! I am still considering whether or not I want to get the woodgrain trim for the dash gauges. I think it looks great against the white CLS gauges but not sure how I would like it with black gauges. I will be posting a how-to for both iPod and Bluetooth install with the stock Bose system so look for that soon. Thanks again for the comments.
'08 MX5 GT 6spd.
to be honest with you, that looks perfect. Dont go overboard. BTW, where did you get the wheel from and how much?
Got the wheel brand new from this guy (Acura dealership)...
http://stores.ebay.com/Acura-of-Esco...QQftidZ2QQtZkm
...for $360. Not cheap, granted, but a hell of a let better deal than retail.
I would consider selling you my old one, bro. However, I'm keeping it packed away for the day I sell the car. I'll most likely get more money for the woodgrain wheel on ebay at that time as opposed to letting it go with the car. Same goes for the shifter knob. They really are more than just looks IMO. Feels classier too. Nice and smooth.
Trilight. :-(
I saw this and wanted to let you guys know that Trilight passed away Aug. 10, 2006. His Acura CL hydroplaned and was struck on the drivers side by a van. I'm so sorry you guys found out so late, but I read on some posts that you didn't know why his pictures weren't working anymore and didn't want you to think he ditched conversations. He was a very close friend of mine for more than a decade.
Please be careful when driving!!!! :-)
GIMBAP
Wow! I'm sorry to hear that. It's kinda getting scary. I mean automakers are increasing the horsepower but people driving habits (common sense) are getting worse especially here in Vegas.
Drive safely everybody!
lowrd on tein CS biatch
yea I got the steering wheel a few months ago right when i got the car and I tackled it myself.
here's a picture I dug up that should hopefully be of some help.
http://s848.photobucket.com/albums/a...t=DSCF0264.jpg
I did everything and then the steering wheel was off by like degree so I had to un-do the main center bolt and re-tighten at the correct angle.
It IS splined, BUT there is a bit of movement and if u are always LOOKING to make 1000000% sure you got it right. you may notice it's not perfect, and have to go back in there and straighten things out literally.
rockyboy
12-06-2022 02:29 PM
