Turbo CL-S Dyno
Old 08-09-2004, 10:16 PM
allmotor_2000's Avatar
Turbo CL-S Dyno *YEAH!!!*
Here y'all go:
419.3 whp
361.2 ft-lbs of torque
At 3K RPM, car has 300 ft-lbs of torque!!
AT 5K RPM, car makes 328whp!!
It was a VERY hot day today... 106 in the valley and 86 at the dyno. I wanted to run
0 timing retard, so I put 50% Motorsport 103 gas and I assume final octane value is around 93-94 octane. It did not ping at 6.1 psi. Exhaust was open as I wanted to see what
this car would put down.
Next step is the extra 750cc injector and ~8-9psi - I am hoping for 460whp. Aso, I only
took it to 6800 RPM... could have taken it higher.
I am now certain that with a 70mph head-wind and 70C temps, the car is putting down
just about 500hp at the crank.
I am just plain stoked!!!
Anybody want to host the dyno plot?!? The plot is a comparison between the old kit and the new one.
Old 08-09-2004, 10:18 PM
slayer202's Avatar
aim: slayer202 or email slayer202@aol.com
ill host
Old 08-09-2004, 10:19 PM
drewLS6 soon
drewJ32A2's Avatar
thats badass
Old 08-09-2004, 10:20 PM
Adventurist.
NiteQwill's Avatar
whoooooooa
Old 08-09-2004, 10:22 PM
Lone Wolf
brian6speed's Avatar
very impressive what do you expect to put down with the injectors and running 8 to 9 psi?
Old 08-09-2004, 10:24 PM
Kenpachi Teichou
oneilc's Avatar
yet again I must to the power!
Old 08-09-2004, 10:25 PM
mattg's Avatar
freakin awesome!
i'll host, pm it to me.
500hp cl-s
Old 08-09-2004, 10:27 PM
something witty
farberstyle's Avatar
holy shit! congradulations!
Old 08-09-2004, 10:29 PM
still a Masshole
ferizzo's Avatar
I think I just jizzed on my keyboard again! Yup, I sure did!
Thats awesome!!!
Old 08-09-2004, 10:32 PM
///M POWER
darrinb's Avatar
great #'s ram, ur the man
Yeehaw
BEETROOT's Avatar
good god
Old 08-09-2004, 10:34 PM
I dyno'd at Church Automotive Testing... he's one of the founders of the TOV site, so I believe he's going to put up the #'s there as well.
I really want to e-mail this to Comptech
Old 08-09-2004, 10:36 PM
ex 6 Speed owner :(
BlueCLS6's Avatar
Mad props to the creator of the most powerful Acura CL ever!!
Old 08-09-2004, 10:42 PM
Chaptorial's Avatar
Good god man.
Amazing.
Old 08-09-2004, 10:44 PM
Haha... thanks man, unbolt that exhaust and mod/prep a few things, you should be right there as well!!
Old 08-09-2004, 10:46 PM
///M POWER
darrinb's Avatar
what would u expect blue to put down ram?? like 390ish???
Old 08-09-2004, 10:51 PM
Dunno... its quite different with the stock exhaust - Blue has the Comptech B-pipe but still the stock mufflers. He needs to go dyno the car, I can't speculate.
We need a stronger ignition system.. I have a misfire at around 5.2K RPM. What I don't
understand is how the stock injectors (even at 90psi) can maintian a 12.4 AFR for this kind of power level. I tuned the car to run 12.0 AFR with the stock exhaust.... opening it up bumps it to about 12.4 which is ideal for maximum power.
In full street-trim (91 octane w/timing retard & stock exhaust), the car probably puts around 370-380whp.
Old 08-09-2004, 10:52 PM
mattg's Avatar
so what could you do w/ a 2.0 60'?
Old 08-09-2004, 10:53 PM
4th Gear
silver6's Avatar
Holy $hiet, Awesome #'s. I'm definitely saving up for the turbo now.
Old 08-09-2004, 10:55 PM
I think a 12.2 @ 117mph with the car prepped properly. With 8-9psi, it will run 11.8 @ 122mph. I don't mind speculating about my car
Old 08-09-2004, 10:56 PM
I still can't get over that this kit made 73.4whp (peak) more than the old kit at pretty much the same boost level - its the power of a good turbo! Thanks to Blue and his buddies at Garrett to help size this beast.
Old 08-09-2004, 10:59 PM
drop em like its hot
rezurex's Avatar
allmotor you're my hero!
Old 08-09-2004, 11:01 PM
CraZee ZO6's Avatar
Very Impressive numbers!
Are you going to do a dyno pull in "street trim" Pump gas, with exhaust and all?
Old 08-09-2004, 11:04 PM
failhard.
mystikk's Avatar
Wow I think I found my A-CL idol. AWESOME numbers man.
Old 08-09-2004, 11:06 PM
THE SILVER BULLET
pimpscls's Avatar
your a cl god
Maybe... I didn't want to pay a lot of $$$, hence I only did three runs and they were all within 5whp.
If I were to ever track it, it would probably be setup similar. I think I could push 400whp with a different exhaust system on 91-octane.
In any case, a dyno is an 'estimate' of actual power which can easily be 5% to 10% more under more ideal conditions and actual air-flow through the IC. A liquid-air IC like Scalbert's would have provided higher #'s.
Old 08-09-2004, 11:15 PM
///M POWER
darrinb's Avatar
matt with those #'s 2.0 60' is def a 11 sec slip
Old 08-09-2004, 11:19 PM
CraZee ZO6's Avatar
So someone who did a setup like this in street trim would expect around 380-390rwhp with exhaust and pump gas? OR would the power be less?
A cousin of mine with a CLS is very interested in doing a turbo kit..
Old 08-09-2004, 11:20 PM
I think so... if they are on the east-coast... probably more around 390whp due to the availability of 93-octane gasoline.
Old 08-09-2004, 11:21 PM
Sweet as Gold
Ant7701's Avatar
OMG....amazing numbers man!!!!! I never ever thought our stock block was capable of 500HP!!!!
You should really think of changing ur user name now
CraZee ZO6's Avatar
Cool thanks for the info.
Again, congrads on the accomplishment.
Old 08-09-2004, 11:22 PM
mattg's Avatar
do you want me to host the graphs?
Old 08-09-2004, 11:23 PM
ex 6 Speed owner :(
BlueCLS6's Avatar
yep, that's what we do. The turbo should be good enough to flow 600hp (crank) for you . Wow, that's over 21% more power at the same boost level... that's impressive. I'd be happy with an even 400whp. Soooo maybe I'll dyno it sometime...
Old 08-09-2004, 11:24 PM
///M POWER
darrinb's Avatar
ram, u thinking of testing out the strenth of the stock internals?? or are ya not gonna take the risk....
what would be really funny is u taking that car in for service at the dealer
Old 08-09-2004, 11:26 PM
mattg's Avatar
i think he said the motor would probably take 600hp.
Old 08-09-2004, 11:28 PM
Shawn showed me the dyno for a G35C with the Greddy TT kit boosting 8.5psi and it made more torque at 3K RPM, but about 50whp less. The extra 300cc and the >2psi of boost can explain the torque... but the CL-S would walk away from 5K to 7K
I'd like to make 100whp more than the greddy TT kit on a Z or G35C at 8.5psi
Old 08-09-2004, 11:31 PM
The RSX can reliably make about 300whp when tuned properly. That translates to about 75whp per cyliner. At that power-per-cylinder, the CL-S can make 450whp reliably. I won't push more than that. That's over 500 at the crank which is at the exotic-car level.
Old 08-09-2004, 11:32 PM
EVO IX MR
2003type-s6's Avatar
Holy Crap!
Old 08-09-2004, 11:33 PM
///M POWER
darrinb's Avatar
wheel or crank??
uh oh ram, the z/g guys are about to chime in and start a war
Old 08-09-2004, 11:35 PM
mattg's Avatar
Quick Reply: Turbo CL-S Dyno
