wheel spacer thoughts?!!
I have a 09 tsx lowered on H & Rs. (1.5 " drop). 19 x8.5 all around with a 34 et .. Car stance is nice as is but looking for a lil more poke on the rear. The fronts are pretty flush but rears can use a lil poke . any suggestions on wheel spacer size 10 mm? Also are these things safe do I have to worry about cutting studs etc. Not looking to extend studs and everything. Appreciate some feed back thanks
Poke means the tire is already sticking out of the fender. And you would make that worse with spacers.
Rear studs come out pretty easy, IIRC. You really should buy extended studs for 10mm spacers.
mtl_ilx
09-03-2015 09:48 AM
