The Tire Selection/Wheel Size Master Guide
Old 05-01-2009, 07:31 AM
  #241
4th Gear
hypeR_ash's Avatar
I just got the eibach prokit installed, along with 18x7.5 +40 works on 235/40/18 tires, and there is rubbing in the rear every time I go over bumps in the road.
Old 05-05-2009, 01:20 PM
  #242
BlackAccordion's Avatar
people...I have read the topic, but unfortunately no one has asked about this size (apart from the information in the firts post)
i have a 2007 honda accord, and would like to get 18" rims, 215/45/18
40 would be too bumpy, so looking at the 45's
the rim will be 7.5", and what offset would you suggest?
Old 05-05-2009, 01:25 PM
  #243
No room in
Takran's Avatar
Generally offset of +42mm or higher is recommended if you're planning on a drop of any considerable amount.
I assume you're talking about the Euro Accord since you're posting in the TSX forum
Old 05-05-2009, 01:58 PM
  #244
Yes, the Euro Accord
But the tires would fit? 215/45/18. I have the stock suspension at the moment..and cannot lower anyways, as it is still under warranty.
Old 05-09-2009, 09:50 PM
  #245
simmykwan's Avatar
just wondering if 18 x 8 +30 front 18 x 9 +30 rear would work on a TSX. thinking of getting one and i want to use my old set of rims. not sure if ppl run 9s on these cars
Old 06-15-2009, 01:10 PM
  #246
6th Gear
lowend15's Avatar
20x7.5 +40 offset with 225/35/20. Chrome. Do it.
Old 07-18-2009, 08:10 AM
  #247
Killaken22's Avatar
20" rims on a TSX, what's size tire's fit well with no rubbing?
Does 225/30 ZR 20"s fit nice on an acura? I dont see it on the fitment chart. Please a little help
Old 07-22-2009, 06:49 PM
  #248
9th Gear
JDMiami's Avatar
20''s? since when are we riding caddys? lmao stay with 18s no drop and if dropped must have camber kit or fender roll ( bad). 17's are perfect on any drop but the bottom is soo prone to getting scraped up at abrupt bumps and high speeds
Old 10-18-2009, 12:47 PM
  #249
5th Gear
steverzzz's Avatar
im still confuse after reading 7 pages and trying to figure out this chart!!! the stress!! i just want to know if i can run 18x8 offset 33 | (Rr) 18x9 offset 38 , also saying i have about a 1.4inch drop
Old 11-09-2009, 12:10 AM
  #250
Dktran31's Avatar
i have stocks wit a 1.9" drop via eibach sportsline, and bumps/potholes are already a huge pain, after i intend on getting 19s, it will be straight hell =0
Old 11-18-2009, 05:51 PM
  #251
nrustam's Avatar
hi. Will 225/55-17 tires fit my '05 TSX oem rims?
Old 01-11-2010, 09:53 AM
  #252
CLK38's Avatar
This looks quite similar with my setup. I am running with Advan RS wheel 17x8 +45, 225/45/17 Pontenza RE001 rubber. Fits perfectly, rear camber -0.5 degree. No rubbing issue. See my photo. (quite identical but is not the same car .. )
Originally Posted by EuroRspec
I have been trying to figure out what the specs are on the wheels below and cant get an answer. This is a look I am trying to accomplish. Are they a 18x8 +40 or +45?
Old 01-11-2010, 06:22 PM
  #253
carmagnut's Avatar
Lovin the Red!!! Nice.
Old 01-31-2010, 06:20 AM
  #254
crazie's Avatar
Hey guys i have a set of 19x8 +38 offset on 245/35 falken fk452's will they fit?? Im looking for a drop in the future to. Will these fit? or should i run some different tires?
Old 02-22-2010, 06:28 PM
  #255
a11u11's Avatar
Hi everyone,
I'm a noob, so please go easy on me. I'm looking for wheels for my stock TSX. Would a 17x7 with a +38 offset fit my OEM tires without any issues?
Thanks in advance.
Old 02-22-2010, 10:12 PM
  #256
8th Gear
r2ro's Avatar
Originally Posted by a11u11
Hi everyone,
Thanks in advance.
I have 18x8 40 offset and they are pretty flush, on the top but they angle a little bit out twd the bottom, less than half inch, so considering your wheel is a half inch less wide than mine from center out.
I believe it will fit, but it will stay pretty flush, which means, as far as I know (and I am also new here, but have read a lot !!!)..you will not be able drop very much to avoid rubbing if that is what you were asking .
Old 03-22-2010, 12:53 AM
  #257
QuadCore's Avatar
Hello all,
I'm considering the Civic JDM FD2 gunmetal wheels for my 2005 TSX with stock suspension. In the future I may lower it about an inch. Anyway, the wheels are 18 x 7.5 with +60 offset. Will this work... since most setups here seem to have smaller offsets of around 33 - 55?
Thanks.
Old 04-23-2010, 03:36 PM
  #258
Thecrazytrains's Avatar
Looking at konig lace 18's. Couldn't find them in 7.5" I know some people have used 8" but never saw a picture and I didn't know if it was a good fit on the tsx. I also wanted to know which offset would be a better pick. I've blown 2 tires this past winter so the lowest I was thinking was 35. Any help would be appreciated Thanks
Old 07-09-2010, 02:42 PM
  #259
DATran's Avatar
Hey guys, I am running Enkei EMK3 rims 18x8 with a 40mm offset. From what I have read from the master guide and from the previous pages I still don't feel 100% confidant in purchasing new tires in fear of rubbing. The car is slammed (ride height) I bought it like that. The rear tires are cambered/tucked in the fender so i don't really know the ride height of my car. The current tires I have on the car are 215/45/18's and according to the master guide I should run 235/40/18's if I want to increase the width of my tires. And also one more thing... Would it be pointless or retarded to run 235/40/18's on the front and 215/45/18's on the rear? I want more grip....and im also scared that the lower side walls will implode if i hit a small pothole.... :/ Thanks guys!
-Dan
Old 08-15-2010, 01:02 PM
  #260
6th Gear
BGCL9's Avatar
Wow this thread is very helpful....now I know what size wheels to go with
Old 08-23-2010, 01:03 PM
  #261
team LoL
undefined.tae's Avatar
wheeL experts...
is it possibLe to run 18x8 with a 29mm offset.?
it's currentLy on 235/40 tires.
can i use these tires or wiLL i need to change them out.?
i'm sure i wiLL need fender roLLing in order to sit fLush.
thanks in advance.
Old 08-23-2010, 04:24 PM
  #262
JTso's Avatar
Originally Posted by undefined.tae
wheeL experts...
thanks in advance.
It depends on the ride height, camber angles, and the actual dimension the particular tires. It will probably fit with stock height but it won't be flush. How about a nice set of SSRs with PS2 tires?
Old 09-01-2010, 05:24 PM
  #263
NewYorker's Avatar
hey guys,
I got TSX 06, and going to replace the tires.. i looked few and need some advise on these tires... what u guys think about...
Hankook Ventus V4 ES H105 215/50/R17
Continental Continental ExtremeContact DWS 215/50ZR17
Goodyear Authority 215/50/R17 (From Walmart)
which ones better or can you guys recommend something..
thanks
Old 09-07-2010, 08:47 PM
  #264
vtboi4sho's Avatar
Wheel Make/Model: Work vs-xx
Wheel Size (18x8front 18x9rear):
Wheel Offset (+38):
If lowered (amount):1.5front 1.0rear
I'm sure someone has asked if these will fit on a tsx with any problems, but my computer is really slow to search through all the pages lol. Also, what tire size should I use?
Old 12-01-2010, 06:19 AM
  #265
nemiga's Avatar
Hello guys,
I've read all the 7 pages but still have a Q: has anybody tried R16 wheels on Acura TSX? Earlier I was told that R16 wouldn't fit because of large size of brake supports on TSX, however the table in the first post reads R16 wheels should fit.
Anybody knows for sure?
Old 12-05-2010, 01:12 PM
  #266
unjustjust's Avatar
Tire sizes 215 50R17 vs 215 55R17?
i just got tires replaced on an acura tsx sedan. stock was at 215 50R17. costco replaced them with 215 55R17.is there any noticeable ride handling difference between 50R vs 55R besides it riding a bit higher? anything else i should be aware of?
Old 01-13-2011, 09:41 PM
  #267
Imperviousrican's Avatar
Konig lace
Does neone have this set up on a 2004 acura tsx
konig lace 18x8
235/40 e 18 tires with a 45mm offset
will it work without rubbing? car is 100% stock
Old 02-11-2011, 09:34 AM
  #268
billjohnson457's Avatar
thanks for all the info
Old 02-20-2011, 07:09 PM
  #269
horst tsx 04's Avatar
I just got new tires 225/45/17 potenza re960's. I'm not sure of the size yet not sure if I need to shocks or tie rods cause the steering feels a loose and on corners a little unsure. I seen the sizing chart and it was within the 2.0 range well 1.9 so right there. I had the 960's in the oem size but got these as they were lots cheaper. Anyone else have this size?
Old 03-30-2011, 09:04 AM
  #270
supafamous's Avatar
Hi,
Thought the wheels I was looking at were +45 but they are actually +40 so now I'm wondering if I'm going to stick out too much. They are 18x8+40 with 235 wide tires.
Does anyone have shots of how flush the wheels are with that setup? And does it rub if there's a little bit of lowering to the car (say 1 inch)?
The alternative for me is to get the 18x7.5+45 and go with 215 wide tires.
thanks,
Old 04-12-2011, 03:44 PM
  #271
accordselux's Avatar
I think you're going to rub with 235's. Why not some 225's?
Old 04-24-2011, 08:34 PM
  #272
importgrl727's Avatar
ok, so I'm a girl, bear with me....
I bought 19 x 8 with a 43 offset.
It looks like ideally I would want 235 35 19
I am not lowered at all, yet
I saw an earlier post about this scenario rubbing
Any suggestions?
Old 04-25-2011, 12:34 PM
  #273
supafamous's Avatar
I'm not lowering much and I'd like to be as accurate with the speedo as I can.
I've gotten the wheels put on and I'm flush in the rear and stick out about 1/8" on the front. With the stock ride height there's no rubbing even with a full load and I'm going to put some H&R OE Sport Springs (F.75", R.5") on it - I expect it to be fine as well even with a full load.
With a 1 inch drop I'd expect rubbing especially with a full load.
Old 04-25-2011, 12:37 PM
  #274
supafamous's Avatar
Any suggestions?
Stock ride height = no rubbing under any scenario (see my above reply) but at that size your car might look like it's raised slightly (mine sure does). If you don't have any plans to lower it or don't mind it looking a touch awkward (only car people will notice) then this setup is no problem.
I'm lowering mine a tiny bit to deal with it and avoid doing any more work on it.
Old 06-06-2011, 01:44 PM
  #275
I'm looking at some wider 17" wheels instead of my 18's.
It looks like with 17x9's I'd need to run 235/45/17's.
How low of an offset can I go with a 17x9 wheel on 235's, as low as possible without pulling or rolling?
I have a rear camber kit btw.
I'm looking at a set of 17x9 +45's, but would like a slightly lower offset if possible.
Old 08-05-2011, 11:56 AM
  #276
DaveLeB's Avatar
Im looking for a tire with a lower profile with stock rims and stock suspension something that would still look good what would be a good size.
thank you
Old 08-10-2011, 05:43 PM
  #277
L.A. > the rest
SLIKRIK's Avatar
thank you
low profile tires on stock wheels and suspension will only create a bigger gap between the tires and the fenders making it look like a 4x4.
keep what u have.
upgrade to low profile tires once u change ur wheels and drop it.
DaveLeB (08-11-2011)
Old 09-23-2011, 12:52 AM
  #278
B A N N E D
619CL9's Avatar
anyone running 18x8 +30 offset??? on a 3" drop?
Old 05-09-2012, 05:07 PM
  #279
juandcmo's Avatar
Hey I just bought my 06 tsx and I'm lookin into buying some new rims for it I got some 19s on it at the moment but I wanna lower It some would it b ok to keep it with 19s or go down to 18s? And I'm look at black Konig afterburners what size do u guys recommend I don't want it sticking out like crazy or rubbing either and how much of a drop do u guys recommend as well ? Any suggestions on lowering? Use coilovers? Or dampners? Or just some springs?
Old 06-11-2013, 06:36 PM
  #280
TsxDaGod's Avatar
I need some help i want to get xxr 527 wheels for a 04 tsx i was planning on getting it 17x9.75 + 25mm would it fit well r should i get 17x8.25 + 25 mm n what size tires should i get im planning on getting falken tires please lmk need some help
Quick Reply: The Tire Selection/Wheel Size Master Guide
