Want to see a 1st vs. 2nd gen TSX race
Poser / Fanboi
Originally Posted by cybereclipse
i believe because of the extra torque, the 09 will pull ahead..
I would also be interested in seeing an '06 6MT hondatafied -vs- '09 6MT - then they would both have the 5k RPM kick.
Detail Cars in Philly in
Originally Posted by slickrab
lol, but how are you going to drive both at the same time?
I'm thinking the first gen will win. Not because I'm biased but the gains in tq is offset by almost 200lbs in weight gain in the second gen. Plus the peak power is absolutely the same from 1st gen(2006-2008) to second gen
I took a test drive of the 09 TSX 5AT with the SS/paddle shifters from a dead stop today with the VSA turned off. going through a gears the added torque made the take-off faster, probably about 7.5-8.0 sec 0-60.
Then, when I got home , I took my 04 TSX 5AT on SS with VSA turned off and it was a dog, about 8.5-9.0 sec 0-60.
Poser / Fanboi
Originally Posted by Mokos23
I took a test drive of the 09 TSX 5AT [...]
Then, when I got home , I took my 04 TSX 5AT [...]
I think it would be more interesting to see what these cars do on a road-race course or auto-x. The torque flexibility of the new engine might be more important in the situations a tight track might put you in as opposed to a drag race, where you can fully wind the car out.
But I agree with Dom. We're still talking about a rather slow car, regardless.
Poser / Fanboi
Originally Posted by dom
'smoke' may be a bit of stretch.
I don't disagree that both cars are slow; I'd use 'smoke' however to indicate the relative degree by which one car beat the other. If an '09 beat an '04 by, say, 3-4 car lengths, then it smoked it, even if both cars weren't all that fast.
I test drove a 09 6mt, compared to my 04 with just a injen sri, it would be close but I think the 04 might win it. Stock vs stock would be even closer, and maybe even turn around the outcome. Its a interesting debate, but we need someone to do a 1/4 mile in one and then right after that jump in a 06 and do the same run. That way there is no driver/conditions advantage.
I really hate discussing this because IMO, it pointless. Neither car serves this purpose well. If I had to guess, I'd say the 09 will be quicker than an 04-05 but then again the only instrimented acceleration testing that was done on an 09 (Jeff at TOV) resulted in a 15.7 1/4 mile. That puts it smack in the middle of 04-08 territory. If not slightly slower. Obviously the 09 tested was green and a number of factors can change those times.
But who really cares about 0.3 seconds.
JLsTypeS (09-22-2013)
iVTEC no koe
I'd believe the '09 would smoke the '04-'05. They don't benefit from the 10+hp gains that the '06-'08 do. I'm still looking for a detailed description of what they did to the motor from '08 to '09: obviously they modified the ECU, since VTEC is lower, but were there other changes in valve size, throttle body etc...?
To achieve these power gains, the engine has a higher compression ratio, new valve timing, and intake and exhaust flow improvements. A new aluminum and resin composite intake manifold reduces weight over the previous aluminum design, while better insulating the engine's incoming airflow from under-hood heat.
INDUCTION SYSTEM
The TSX's induction system has been reworked to increase airflow volume by nine percent and to create a more aggressive, linear engine sound. The revised inlet design allows cool ambient air to be picked up at the front of the vehicle, and then routed though a high-flow filter assembly. The single-stage lightweight plastic intake manifold has fixed-length intake runners that are tuned in length, diameter and shape to provide an optimal blend of low-rpm torque and high-rpm response. The new manifold incorporates new 48 mm intake runner (up 6 mm from the previous design runners) along with a new throttle-body with a 4 mm larger inlet opening.
CYLINDER HEAD / VALVETRAIN
Larger intake and exhaust valves and revised ports contribute to improved breathing. An increase in compression ratio from 10.5 to 11.0:1 is a significant contributor to the TSX's greater torque output.
EXHAUST SYSTEM
To help boost engine torque, the TSX has a new high-flow, low back-pressure exhaust system that contributes to a 15-percent increase in exhaust flow over the previous TSX.
Source:
http://www.hondanews.com/categories/742/releases/4439
2006 TSX Equivalent:
http://www.hondanews.com/search/release/2836
Poser / Fanboi
Originally Posted by HoRRo
Highlights: [...]
any vids yet?
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
Eggs999bacon
09-24-2015 10:08 AM
