TSX Stock Grounding
TSX Stock Grounding
I recently purchased a TSX, with the negative terminal just going to the fender---1 wire to the fender
This does not seem appropriate for grounding the car, and the start does seem a little slow.
Can someone please elaborate on their grounding + pictures if possible.
That's normal . There are a few other grounding points as well. Clean your terminals to see if that helps . Or try a new battery. With dropping temperatures, a weak battery and poor starting issues can be exacerbated
On my 4runner there are 4 grounding points, one to engine, one to negative on the starter as well I think, is this normal
There are other grounding locations, but your question was, "one from battery to fender". yes. that's one of them, there should be others as well. engine to body, etc. look in your bay and you should find them.
yes i seen a few looking briefly, but from the actual battery only the one cable, could you maybe show a pic of yours?
Raise voltage...
You can potentially decrease voltage drop... but 'raising voltage' is not really correct here..
Big 3 is nothing new though https://www.google.com/search?q=tsx+...hrome&ie=UTF-8 Tons of done it!
