TSX Navigation/Audio Codes
Old 12-14-2006, 05:00 PM
3rd Gear
schulze's Avatar
Hello
I was abel to enter the Navigation code in our 2004 TSX however I can NOT get to a screen that allows me to enter the AUDIO code.Once the navigation code is entered the map comes up and I can NOT find a way to get any audio screens.Any help you can offer will be greatly apreciated!
Thank you
Christian
Old 12-14-2006, 05:15 PM
jmathew34's Avatar
try and press the am/fm button and see if that works...
Old 12-15-2006, 09:08 AM
Reach's Avatar
You enter the audio code by rotating the station select knob to select a number (the right one, not the volume one) and then depress it to enter the number you've selected.
Old 12-15-2006, 10:45 AM
3rd Gear
schulze's Avatar
TSX Codes
Hello
Thank you for the replys.I tried the AM/FM button Nothing.I can NOT get a screen that will even allow me to put the code in. The screen is the map or BLANK.Thank you!
Old 12-15-2006, 02:28 PM
Summer is Coming
Rocket_man's Avatar
From the Owners Manual
"If your vehicle’s battery is disconnected or goes dead, the audio system will disable itself. If this happens, you will see ‘‘CODE’’ in the frequency display the next time you turn on the system. Use the preset buttons (icons on vehicles with
navigation system) to enter the fivedigit code. The code is on the radio code card included in your owner’s manual kit. When it is entered correctly, the radio will start playing. If you make a mistake entering the code, do not start over; complete the five-digit sequence, then enter the correct code. You have 10 tries to
enter the correct code. If you are unsuccessful in 10 attempts, you must then leave the system on for 1 hour before trying again. If the code card is lost, a dealer can access your code with your radio’s serial number. To access the serial number, turn the radio on. It must display ‘‘CODE’’, then turn the radio off. Push the preset 1, preset 6, and power buttons at the same time, then quickly release.
You will have to store your favorite stations on each side of the preset buttons (1 6) after the system begins working. Your original settings were lost when power was disconnected."
You can power off the system by pulling the #7 (10A) fuse in the under-dash box and start over again. If the power was off long enough it may take some time for the GPS system to initialize.
Old 12-15-2006, 10:30 PM
Reach's Avatar
Originally Posted by schulze
Hello
Its not on your nav screen. Its above it, where the clock / temp display is.
Old 12-19-2006, 04:09 PM
3rd Gear
schulze's Avatar
Thank you!!
Hello
Thank you for that info! The lights do NOT work around the clock so I didnt even think to look there! I was abel to use a flashlight and enter the code and all is well! Right now Im waiting for a letter from the original owner to transfer the Acura Certifed 100K warrentty. Honda /Acura Of America make you fight for that! I was abel to get the original owners info from USER 1 of the Navigation system.Hoping taht goes well so we can get the light problem fixed.Anyways THANK YOU again for ALL of the info above!
Christian
Old 12-16-2010, 12:03 AM
Los Che's Avatar
Hello.
I am glad to join you. I bought Acura TSX 2004. I have a problem with navigation code and radio code. I am from Belarus and there are not present Acura's diller. Please help to receive this codes. VIN JH4CL96934CO29171. code U1000, L3398.
If someone would be so kind as to send this to my email DrozdovAM@yandex.ru I would be extremely greatful. From me Russian beer.
Mike Pilipenko
03-26-2024 09:21 PM
TypeS860
09-03-2021 06:42 PM
mlody
12-04-2019 02:11 PM
MilanoRedDashR
10-02-2015 10:49 AM
Skirmich
10-01-2015 12:59 PM
Quick Reply: TSX Navigation/Audio Codes
