Repair Glove Box that won't open (detailed instructions available for download)
Old 08-25-2013, 01:31 PM
blevine's Avatar
There appear to be many posts about glove boxes that won't open in the TSX 1st GEN and other models. It appears that the majority of the failures are in the lock mechanism (top left) and not the latch mechanism (in the centre). You can determine this by peering behind the handle on the lock mechanism and using a screwdriver to push the end of the linking wire. If it releases the latch, this confirms that the lock mechanism is at fault. This post addresses a failed lock mechanism.
The common response from dealers is that the whole glove box assembly must be replaced because the broken elements are sealed inside. However with a little bit of work, it is possible to take apart the sealed unit, repair the lock mechanism, and put the whole thing back together.
[Disclaimer: There is no guarantee that you will not damage the glove box provided here will solve your particular situation.]
Detailed instructions, including pictures, can be found here:
https://docs.google.com/file/d/0B7Zv...it?usp=sharing
Old 08-25-2013, 06:39 PM
Old Guy
Simba91102's Avatar
Interesting that you seem to think it's a not uncommon occurrence. I've been here for over 6 years, and I can remember.... well, I only need one hand to count the number of times of I can remember reading about this problem. Thanks for helping out though.
Old 01-15-2017, 09:41 PM
ran-d2007tsx's Avatar
Add one more to the count, mine has this issue. Too bad the link for the fix no longer works.
Old 07-17-2019, 10:48 PM
evident's Avatar
Anyone have the instructions on how to repair a glovebox that won't open?
Old 01-24-2021, 11:08 PM
4th Gear
boostdashcancel's Avatar
I know it's late but I just decided to fix this problem on my own TSX so I'm posting it for the next guy.
ANDYK803
1/2G MDX (2001-2013)
06-26-2013 10:13 PM
SIM
1G TSX Problems & Fixes
08-07-2009 12:18 AM
CL-Slick
06-19-2008 01:49 AM
wtwoot
04-06-2008 07:54 PM
moeronn
Home & Garden
09-11-2006 07:53 AM
Quick Reply: Repair Glove Box that won't open (detailed instructions available for download)
