Squeaking/Creaking sounds when pressing on brake pedal
Old 09-19-2013, 11:01 AM
TSX
Savio's Avatar
hello all,
I have a 2005 TSX with almost 100k on it. This issue arose a couple of days ago during the drive home in LA traffic which is all stop and go. I noticed when pressing on the brake pedal, it makings a creaking/squeaking sound. I'm not exactly sure where it's coming from but hopefully one of you guys here have come across this issue.
Here is the exploded diagram of the assembly. Should I be looking at part #6 and using lithium grease there?
Thanks in advance.
Old 09-19-2013, 04:36 PM
Jottle's Avatar
How loud is the noise? I've noticed that the "whoosh" air pressure sound that the brake pedal makes on these cars is unusually loud. If I'm going under 25, I can clearly hear it no matter how lightly I push on it. Is yours more of a loud creak or a higher pitched squeak?
Old 09-19-2013, 08:08 PM
TSX
Savio's Avatar
It's loud and it's creaking. It's definitely not the "whoosh" sound. I can pulse the brakes and hear it consistently. If I press 50% and release to 25% on the brake I can hear it but from 50% to 100% (going down all the way), it does not sound. If I can get get some audio/video, I will post it.
Old 09-20-2013, 12:45 PM
TSX
Savio's Avatar
Old 10-30-2013, 06:45 PM
cbeach's Avatar
Mine just started doing that last week. It sounds exactly the same.
Old 02-08-2014, 04:20 AM
kewlliljethro's Avatar
Has op or anyone solved this? I have the same exact symptoms
Old 02-08-2014, 05:42 AM
Old Guy
Simba91102's Avatar
What a weird sound, and your question is a good one. Odd that there's no follow up on this, but that's not unusual. I guess it doesn't occur to many to share the answers to their questions if and when they solve the problem. I'd suggest finding someone to push the brake pedal while you stick your head under the dash and watch and listen. The noise sounds like it's inside and pretty noticeable, and I can't imagine that you couldn't identify it if you can get close to it.
Old 02-08-2014, 09:54 AM
TexasHonda's Avatar
Suggest spraying WD40 on brake pedal pivot bushing first to see if pivot bushing is source of problem. WD40 will penetrate and temporarily lubricate. Considering difficulty of accessing/replacing pivot bushing, this may be the best "long term" solution.
You could also spray the brake light switch (part 6) w/ WD40, but I doubt it's the source of this noise.
If not brake pedal pivot bushing, it could be the brake booster push rod is dragging on the boot. Again hitting w/ WD40 will confirm source of noise and offer temporary fix.
Other spray lubes may last longer. WD40 tends to evaporate, but is non-staining in my experience.
good luck
Old 02-10-2015, 09:52 AM
vtech-erick's Avatar
Has anyone resolved this issue? I sprayed lithium grease and had no effect to the noise.
Old 02-12-2015, 08:52 AM
TexasHonda's Avatar
Lithium grease will not penetrate to reach squeaking surfaces. A light penetrant oil such as WD40 is necessary.
A squeak can sometimes be located by touching surfaces to feel the vibration.
good luck
Old 02-20-2015, 03:45 PM
I tried WD40. Had not affect on the noise. Any other ideas?
Old 02-21-2015, 09:20 AM
TexasHonda's Avatar
Confirm noise source is from brake pedal pivot bushing/bearing, remove, and repair/replace assembly.
good luck
Old 11-26-2016, 09:29 AM
Derrick J Richards's Avatar
Did
Did you figure this out? I have the same problem
Old 02-11-2018, 02:40 PM
5th Gear
breadfish's Avatar
I had this problem on a 2006 TSX, and just fixed it.
Sprayed a tiny amount of CRC white lithium grease where the pivot pin rotates in each hole on each side of the pivot.
I may not have explained that very clearly, so here's a picture that hopefully helps.
The red arrows show the two spots where I sprayed:
Squeaking/Creaking sounds when pressing on brake pedal-w4grpbk.jpg
The grease can came with an extension tube (basically a skinny straw) that I used to spray the grease right onto the pivot holes. I sprayed just a tiny amount on each spot, and it worked, squeak is gone.
mada51589
05-03-2022 08:54 PM
pgeorg
3G RLX (2013+)
33
09-16-2015 07:40 PM
09-15-2015 06:44 PM
Ny1718
09-11-2015 09:21 AM
HOWELLiNC
09-10-2015 01:39 PM
Quick Reply: Squeaking/Creaking sounds when pressing on brake pedal
