2007 TSX Blinker
Old 12-08-2021, 06:13 PM
Knagy1125's Avatar
2007 TSX Blinker
my acura blinker stopped working. just the left, the right works fine. when i put hazards on, left still doesnt work, and right is fine.
bulbs checked, relay replaced (and expensive non returnable part). ideas?
Old 12-08-2021, 09:22 PM
Received 8,582 Likes on 6,629 Posts
How did you “check” the bulb? Have you tried just replacing it
Old 12-08-2021, 09:35 PM
Knagy1125's Avatar
Yea check for broken inside and replaced front and back as well. The inside bash doesn’t light up either
Old 12-10-2021, 04:24 PM
SpiderX1016's Avatar
I would replace the Turn Signal/Hazard Relay located at Driver's Under-Dash Fuse Box. Be careful with the tabs on the side, it's a little tricky to remove and they break easy.
kennethklee
05-27-2006 07:53 PM
Quick Reply: 2007 TSX Blinker
