SRS Codes
Old 07-01-2015, 08:33 PM
4th Gear
JMLaminack's Avatar
SRS Codes
I am having trouble deciphering my SRS codes. I have followed the procedure for retrieving the codes and have got the following:
4 long blinks, 6 short blinks - 4-6
4 long blinks, 5 short blinks - 4-5
4 long blinks, 4 short blinks - 4-4
I have found the meaning for codes 4-5 & 4-4, but for 4-6 I can't find any information.
Any help would be much appreciated.
Old 07-02-2015, 08:25 AM
TexasHonda's Avatar
46 - No signal from left side impact sensor (second sensor) and/or internal failure of left side impact sensor.
45 - Same as 46 for Right side impact sensor (second sensor).
44 - No signal from left side impact sensor (First sensor) and/or internal failure of left side impact sensor.
Have you had an accident? Get a shop manual if you intend to DIY.
good luck
Old 07-05-2015, 11:34 AM
4th Gear
JMLaminack's Avatar
The car has been in an accident in the past.
I have a service and shop manual for a 2004, but the codes weren't the same.
Does the 2006 model use different codes?
Old 07-05-2015, 11:43 AM
4th Gear
JMLaminack's Avatar
Would these be the correct codes?
Old 07-07-2015, 06:49 AM
TexasHonda's Avatar
Unfortunately I'm on the road and don't have my manual w/ me. If you have a shop manual for your model, I would go w/ that.
good luck
Old 07-10-2015, 08:13 AM
4th Gear
JMLaminack's Avatar
Please let me know if you get a chance to double check
Old 07-11-2015, 11:17 AM
TexasHonda's Avatar
Your codes are correct for 04-05 model. They are different for 06-07 which is what I saw in shop manual for 04-07.
good luck
Jamus22
06-11-2023 10:08 AM
brboy
10-05-2015 11:34 AM
MilanoRedDashR
10-02-2015 10:49 AM
thegipper
09-28-2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
09-28-2015 12:33 PM
Quick Reply: SRS Codes
