Gauge Module Cluster problem - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 01-22-2013, 08:49 AM   #1
Registered Member
hi, I have an '06 TSX, 140k miles. In August '10 I had to replace the Gauge Module Cluster because I had no dash board lights (no Tach, no gas gauge, no MPH, completely dark). When the dash lights quit, I also had no A/C. The pull code at the time was U0155. In addition to the Gauge Module Cluster, they replaced the battery also. A year later, I had the same issue. Took it back to the dealer, this is what they found......Scan for DTC's with HDS, found U0155 (PCM Gauge Ctrl Module), P0462 (Fuel level sensor low). Fuel Gauge and Cluster appear to be working normally, DTC's were set in history (not recent), passed necessary tests for short circuits, low voltage, etc. Checked connections at battery (OK), vehicle operating normally at this time and after several restarts, error lights did not reset.
So now here I am in January 2013 and once again I have no dash board lights. Has anyone ever experienced this problem? Any suggestions? I have an appointment with the dealer next Tuesday.
Jackie
MaxCockers is offline   Reply With Quote
Old 01-22-2013, 08:51 AM   #2
Jackie, sorry for your problems
justnspace is offline   Reply With Quote
Old 01-25-2013, 10:06 AM   #3
Registered Member
Soooooo, since I have not gotten any responses, this confirms my hunch that my problem is not very common.
Old 01-25-2013, 01:43 PM   #4
Old Guy
Simba91102's Avatar
Quote:
I don't doubt that others have had some problems, but except for some 04 models, the kind of electrical problems you're having seem to be extremely rare with the TSX.
Simba91102 is offline   Reply With Quote
Old 01-30-2013, 07:58 PM   #5
Registered Member
If anyone is interested in the rest of my story.......Dealer tells me it's the Gauge Cluster Module AGAIN! Three times in 2 1/2 years. So I called Acura Client Services and they have agreed to pay for 80% of the repair. In the meantime, they gave me a 2013 ILX, so I'm happy.
Old 01-31-2013, 05:39 AM   #6
Old Guy
Simba91102's Avatar
Well, third time is the charm, but.... I can't help but think that there is a problem somewhere else that is causing your cluster failures. Hope you make out, but I wouldn't be surprised if you continue to have trouble. If it were me, I'd fix it and get rid of the car ASAP (actually, I would have done that two clusters ago).
Old 01-31-2013, 03:46 PM   #7
Registered Member
I am also suspecting that something else is causing the malfunction....I have an '06 TSX for sale! anyone interested? LOL
Old 01-31-2013, 05:36 PM   #8
Registered Member
Jackie
This problem is very rare. I have not heard of it before on these forums and I have been reading these forums for years. The problem that i have heard before is with the 2004 TSX models and their "center stack" lights going out (the lights including the radio.) But even the 2004 models did not have problems with their instrument cluster lights going out.
Miamicarfan is offline   Reply With Quote
The Following User Says Thank You to Miamicarfan For This Useful Post:
MaxCockers (02-03-2013)
Old 08-23-2015, 01:02 AM   #9
New Member
Same problem exactly
06 tsx, 105k miles.
R1200RT is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Center Module Unit help | air/heat not blowing Rachel Lu First Generation TSX Discussion (2004-2008) 3 09-27-2015 09:53 AM
Audi: e-tron quattro News Yumcha Automotive News 1 09-18-2015 05:09 PM
Buying a Type S, but Dealership is trying to diagnose electrical problem first. brandnewcolony Third Generation TL (2004-2008) 53 09-12-2015 10:39 AM
Quality Control Issues for the 2016 ILX SpraykwoN Acura ILX Discussion 13 09-11-2015 08:45 PM
Tranny only 2 years old, pressure switches already bad??? HeloDown 3G TL Problems & Fixes 4 09-08-2015 06:51 PM
Tags
05, 2004, 2005, acura, cluster, control, error, fail, gauge, low, module, mt, panel, tl, tsx, voltage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
