clicking noise from gear shift area
#41
04 CGP, quartz, navi
Originally Posted by Miamicarfan
Michael05:
How many miles have you put on your car after the problem was fixed last year? Also, please check back with the board after you have finished placing about 20,000 miles after the fix.
Other members of this board have fixed the problem only to have it return at a later date after a certain number of miles.
Anyone tried the dynomat, felt, or greasing ideas kolt45tsx suggested?
#43
'08 TSX auto with 42K, just developed the same symptoms. This is an older thread, but I feel it's worth resurecting because others are probably having the same experience.
The described "rolling marble" noise just started a few days ago. I've removed everything from the storage compartments, with no relief. As others have posted, I can duplicate the problem at will.
I will take the information from post #30 (thank you) to my dealer and report back.
#44
Are you the original owner of the car or did you buy it used?
#45
Dealer today "adjusted shifter/brake release switch and greased moving shifter components." I've not applied a stethoscope to the center console, but the noise appears to be remedied.
JCash23 (09-04-2022)
#48
check out post #25 in the link below. This forum member fixed the problem.
https://acurazine.com/forums/1g-tsx-problems-fixes-128/2005-tsx-automatic-transmission-noise-671861/
#49
Same noise different situations.
OK, so my 03 tl-s is making the same noise as when you hit the brake ( park switch/ solinoid). However mine amdoes it in the morning when it's very cold, I go through some high water ( only did that once), has done it a few times on the highway in the morning when it was very cold (20f). It clicks multiple times and the gear lights on the cluster blink with the light. When its in neutral I have to wiggle the shift knob to get the N light to light up. I was really surprised to see that high water affects it. Maybe there's a seal gone bad under the car allowing moisture to collect. Has never done it while the car was warm.
Hate to revive an old thread but everyone else's symptoms don't seem to match up with mine too much. Any help is appreciated, thank you! Oh and I did have the trans replaced with one with 100k on it. It's been about 14k since installation. No other issues. My car has 204k on it.
snorf
11-04-2019 06:44 AM
Mike Bertram
09-10-2015 09:27 AM
