2004 Tsx AC compressor won't turn on, how to override?
Old 07-27-2016, 07:35 PM
usmarinedelta's Avatar
So my ac just stopped working today out of the blue. I tried jumping the two prong switch on the High pressure side and only the fan turn on. I have replaced the AC clutch relay and tried swapping them with new ones without luck. I brought it to a shop and they said there was something clogging it to prevent filling it with freon. I didn't believe them so I went and put some freon in from those cans and it filled up fine.
Is there a way to over ride and jump start the ac clutch? Thank you.
Old 07-27-2016, 09:06 PM
aedavis's Avatar
Just responded to your PM about my AC experiences. If you end up repairing it yourself, please post up what you see when you open up the system - I'm curious about what you find.
Old 07-28-2016, 06:31 AM
Thank you. I am going to just buy and replace all the parts, the compressor and condensor.
Will I need to add any more oil to the condenser and what other things I should replace?
There are 2 options for compressors from RockAuto
2004 ACURA TSX 2.4L L4 A/C Compressor & Component Kit | RockAuto
Which one do I get
beaglepower
08-15-2016 07:27 PM
jermo537
1G TSX Problems & Fixes
07-26-2016 12:12 AM
dnguyen1995
07-15-2016 10:31 PM
fury
06-27-2016 06:48 PM
YungGuap
02-03-2016 11:27 AM
Quick Reply: 2004 Tsx AC compressor won't turn on, how to override?
