Exhaust tip w/ bodykit
Old 06-01-2005, 09:16 AM
Noobie 6MT driver
TSXDude's Avatar
I was looking at the instruction for the rear bodykit, and it indicated that the stock exhaust tip is to be removed and replaced with a different one. I thought they were the same. Do i need a replacement one if i were to install the rear skirt?
Old 06-01-2005, 09:19 AM
BallsOfSteel's Avatar
You dont really have to remove the stock tips if you dont want to but the replacement tips are about an 1 inch longer to support the look of the body kit. The replacement tips comes with the rear body kit so you dont have to worry about ordering replacements at all.
Old 06-01-2005, 09:27 AM
i want to ride my bicycle
leftride's Avatar
on a somewhat related note, if you do remove the tips make sure you use a lot of wd40 or something to remove the rust (assuming there will be some) from the nut holding the tip on.
Old 06-01-2005, 09:31 AM
Noobie 6MT driver
TSXDude's Avatar
Thanks guys
Old 06-01-2005, 09:39 AM
JTso's Avatar
The extended tips are also there to prevent melting of the exhaust opening of the lower spoiler.
Old 06-05-2005, 02:11 AM
Someone stole "My Garage"
curls's Avatar
Can someone WITH the OEM kit and WITH the longer tips please let me know some kind of measurement as to how far in/ot the end of the tip is supposed to be in relation to the bumper?
Reason I ask is because I just bough tmy PWP TSX (2004) and had them put a kit on. Since it didnt come from the factory as such, I'm afraid they might JUST put the kit itself on and not put the new exhaust tips on. I want to be sure they do so and measurements will definately help this cause.
Thanks!
~Eric
VIN 00032
Old 06-05-2005, 07:58 AM
Slippy maybe...
ryanhook's Avatar
Actually, I discovered after installing my kit that the replacement tips were the same length and diameter as the stock ones I removed. I had figured they would be longer, but nope.
Anyone else actually compare the two?
Old 06-05-2005, 10:52 AM
Hondaholic
LannyM's Avatar
The only difference is the placement of the mounting ring inside the tip. The tip for the body kit has the ring 1/2" closer to the the rear of the tip, effectively moving the tip outward by 1/2" so it sits flush with the lip.
Old 06-05-2005, 04:18 PM
curls's Avatar
So if it's not moved, I can move it myself w/ no problem?
Old 06-05-2005, 05:46 PM
Hondaholic
LannyM's Avatar
No, that ring is welded inside the tip. And it's split open from there back...........
This is the stock one-the ring is right on the edge on the new one.....
Old 06-05-2005, 06:36 PM
curls's Avatar
That is really helpful, thanks!
So, if I bought the bodykit from Acura and said "install this", they technically HAVE to put the longer tips on, right? Anyone know if the long tips come part-and-parcel with the underbody/aero kit (not getting the trunk spoiler, just the skirts).??
The car is used, being bought from the dealer. The least I'd expect would be new tips to go with the bodykit, but, I want to know for sure so that when I pick it up I don't have any surprises.
Anyone know the measurement of the end of the tip, to a fixed point on the bodykit? If it's less, then I will be asking for new tips.
Thanks!
~Eric
Old 06-05-2005, 07:42 PM
Hondaholic
LannyM's Avatar
The tips come in the box with the rear lip; they should install the new ones and give you the old ones.
Old 06-06-2005, 12:59 AM
sho-one's Avatar
does anyone know if the euro-r kit comes with extended exhast tips too or if they are also required?
Old 07-28-2005, 09:59 AM
RMATIC09's Avatar
IM not quite follownig this, if i have an aftermarket exhaust (fujitsubo) am i going to have trouble installing my OEM kit?
Old 07-28-2005, 10:10 AM
send me a link to JDM??
TSX.Fury's Avatar
I don't think you should. This is talking about the OEM exaust tip. They had to make it stick out further with the OEM body kit, otherwise it would look funny, so there's another tip replacement for the OEM bodykit.
Old 07-28-2005, 02:01 PM
Hondaholic
LannyM's Avatar
The Fuji seems to stick out a little more than the stock exhaust, so it should be great with the OEM kit.
Old 08-03-2005, 07:31 AM
RMATIC09's Avatar
nice, good news...becuase my exhaust seems to hang a bit, wonder if this will cover it up...anyone got any pics of fuji exhaust w/ oem kit?
Old 08-03-2005, 08:05 AM
She said: it's GINORMOUS!
mg7726's Avatar
rmatic did you get your oem kit yet? i'm tired of looking at your nice car w/o it
Old 08-03-2005, 09:34 AM
RMATIC09's Avatar
nope still waiting for another paycheck (im in the mortage business, have a deal closing soon,) , waiting for that check before i go and get it...
(plus some headers )
Ill post pics as soon as i have it...
08_UA7_Gr33k
02-11-2016 02:17 PM
joflewbyu2
10-08-2015 11:16 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
jmaxima03
09-27-2015 10:22 AM
ivan06106
09-26-2015 04:38 PM
Quick Reply: Exhaust tip w/ bodykit
