buying a used hondata TSX?
Old 12-20-2016, 08:05 AM
c0mmon's Avatar
I am looking at buying a 2006 TSX Manual transmission ECU Hondata Reflashed for a 2006 TSX Manual Transmission, to verify, i will still have to get the immobilizer reset but I can do this?
Old 12-20-2016, 08:12 AM
Received 16,260 Likes on 11,971 Posts
the dealership or an expensive scan tool akin to the HDS (honda diagnostic system )
Old 12-20-2016, 09:52 AM
c0mmon's Avatar
so in summary I will be fine buying the ECU, I just have different options to reset the immobilizer?
Old 12-20-2016, 09:57 AM
thisaznboi88's Avatar
should be fine with the ecu. I can probably help you with immobilizer programming if your are in the US. Just wonder are you going to just do bolt-on or do you have bigger plans? Might be worth it to get a full hondata instead of just a reflash, but it really depends on your goals.
Old 12-20-2016, 10:01 AM
c0mmon's Avatar
I am in NJ and worried about downtime.
Not even going to do bolts on probably, only mod to engine i expect to do is the hondata intake maniford gasket as well.
Car has 166k on it this is as much as an investment as I should make i think in performance engine wise
Old 12-20-2016, 10:07 AM
what is the reflash set for? Hondata has different programs that load in depending if you have an intake, headers, exhaust, and etc. for the reflash
Old 12-20-2016, 10:13 AM
c0mmon's Avatar
I was under the impression that unless you paid them extra they gave you a basic tune. Is this not correct?
Old 12-20-2016, 10:35 AM
Here reflash vs kpro
Hondata K-Pro and reflash FAQ/Tuning resources - Club RSX Message Board
per hondata website
https://www.hondata.com/reflash-cate...flash-tsx-2006
Old 12-20-2016, 10:46 AM
c0mmon's Avatar
Yes the Hondata is a far better fit, I've had tec 3 full standalone before and don't have the complexity to warrant it
