04 TSX 6spd with 04 Accord 5spd Questions
Old 02-20-2017, 12:09 PM
WheelD's Avatar
Question 04 TSX 6spd with 04 Accord 5spd Questions
This is an unusual swap I get it. Reasoning is I purchased a 04 TSX 6 Speed with bad tranny, instead of buying a $1000+ TSX transmission I was able to source a K24 Accord 5 speed manual for $150. Everything bolted up fine except where the shift linkage connects on the TSX tranny there is a solenoid I believe for the reverse switch. The Accord transmission does not have this. I have tried taking this off of the TSX tranny to swap over to the Accord tranny but it wont come out. Do I have to split to the transmission case in order to pull this part out? Please tell me I dont.\
See attached pics for the difference between the two.
Attached Thumbnails 04 TSX 6spd with 04 Accord 5spd Questions-accord.jpg   04 TSX 6spd with 04 Accord 5spd Questions-tsx.jpg
Old 02-26-2017, 10:24 PM
WheelD's Avatar
Ok I figured it out, this might help someone else who attempts this, but basically you dont have to swap this part over to the Accord tranny, you just leave the plug unplugged. Transmission works fine as it should, I just have 5 longer gears now instead of 6 shorter ones but it beats spending 8 times or more on a TSX tranny.
Old 12-05-2019, 01:17 PM
Jae_Rex's Avatar
I'm moving up to my TSX from a 03 Accord MT. I die with a ball joint and clutch failure. Maybe I should save the motor (sell) and save the tranny for future use.
mrj1813
05-28-2019 10:17 PM
ODUB
06-06-2006 04:41 PM
dosa
09-12-2003 09:56 PM
Tom2
03-11-2003 02:09 PM
Quick Reply: 04 TSX 6spd with 04 Accord 5spd Questions
