1997 2.5 Acura TL Misfire.
Old 10-20-2012, 06:38 AM
vybz76's Avatar
Thumbs up 1997 2.5 Acura TL Misfire.
I have a 97 TL and it is misfiring still after I changed the sparks plugs, distributor and injectors.Please Help Me.
Old 01-14-2013, 08:54 PM
bischoff's Avatar
was the spark plug tubes dry?
Old 01-14-2013, 08:59 PM
vybz76's Avatar
Yes they were dry.
Old 01-14-2013, 09:00 PM
bischoff's Avatar
next check with a scanner is the timing is changing under acceleration. if it is not replace the cam/crank sensor it is behind the timing belt. While your there might as well change timing belt/waterpump and look for seperation of the back pulley on the balancer
Old 01-14-2013, 09:06 PM
vybz76's Avatar
Have you owned a 2.5 TL. I even change the engine over the summer and the problem still exist. The engine had 40k on it.
Old 01-14-2013, 10:10 PM
main70072's Avatar
It could be bad gas, bad fuel pump, clogged cat converter, O2 sensor(s)...
TL-Rocket
04-29-2023 02:33 AM
sockr1
10-01-2015 01:31 AM
asahrts
09-04-2015 05:55 PM
LAMike240
09-03-2015 04:35 PM
Quick Reply: 1997 2.5 Acura TL Misfire.
