Valve cover gasket - AcuraZine - Acura Enthusiast Community
Valve cover gasket
Thread Tools Search this Thread
Old 05-19-2011, 08:29 AM   #1
New Member
Valve cover gasket
I've got a small leak from the valve cover that is leaking to the exhaust manifold and smokes really bad most mornings. I've been told to change the gasket and things should be ok. Is there a trick to replacing it?
bonghit is offline   Reply With Quote
Old 05-22-2011, 07:53 PM   #2
Registered Member
Tell us what TL you have, 2.5 TL presumably since you said singular "valve cover", but humor us w/ the info.
Generally valve cover gasket and spark plug tube seals will do the job. On 2.5TL, the space to reinstall cover w/o disturburbing the gasket in the cover is limited.
good luck
TexasHonda is offline   Reply With Quote
Old 05-29-2011, 10:59 PM   #3
Registered Member
Goro_98_2.5's Avatar
I don't know how old your gasket is, but I changed mine once and it still leaked a little, it turned out I didn't put enough sealant on the squared off corners where it sits around the camshaft. I took it off and was a little more generous with the sealant and it hasn't leaked since, that was over 2 years ago, but if the gasket is old and brittle, just change it.
Goro_98_2.5 is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Ft front axle leaking Mike734 2G RL Tires, Wheels & Suspension 1 03-02-2016 09:24 AM
FS: Black rear center console garnish, 3.2 VTEC IM cover and gasket InFaMouSLink Car Parts for Sale 6 10-27-2015 07:52 PM
Driver Fan blower change mode by itself hashbrown Fourth Generation TL (2009-2014) 2 09-29-2015 01:13 PM
EGR Valve /Extended emissions warranty shawnafoxx First Generation RL (1996-2004) 2 09-28-2015 01:33 PM
2004 Acura TSX Oil Leak - Oil Pump vs. Solenoid 2.4 i-Vtech IBankMouse First Generation TSX Discussion (2004-2008) 5 09-27-2015 01:30 PM
Tags
1996, 25, 25tl, 96, acura, acurazine, change, cover, gasket, replace, seal, sealant, tl, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
