Radiator Replacement D.I.Y... Pics.
Coolant was being spewed all over my motor. I drove it for 800 miles like this because it wasn't too bad.
Bought a new one on Ebay $108 shipped.
Here is the crack...common place on these cars.
I put my car up on jack stands for more room to work.
Remove the plastic cover under the car with a 10mm socket.
Start by removing the petcock (be sure you have a catch pan)
and let her drain (removing the cap helps it drain faster).
You can also start removing the bottom fan shroud bolts (rusty in this picture four on the bottom and four up top) 10mm.
MAKE SURE your old radiator cap is the same as the new radiator. Mine wasn't it was the same as a 2001 Accord coupe V6. I had to buy a new one at Schlepp Boys.
Remove all hoses underneath and disconnect the one electrical clip.
Be ready with your catch pad because the transmission lines will leak!
Remove the top brackets, top rad hose, and the 4 10mm bolts. Get a friend to lift the radiator out while you are underneath finagling the radiator up and out.
Transfer any fittings such as the temp sensor.
OLD
NEW
Install is reverse of removal.
Make sure you bleed the system by opening up the bleeder valve on top of the Thermostat housing. Fill the radiator until the coolant comes out of the top and out of the bleeder.
If you have air in the system, the car will overheat and you will have no heat.
Good luck!
OLD
NEW
Good luck!
DIY-ish (09-30-2012)
I only did the bleeder valve shown, I did not know there were 2! The motor got a wash when I finished. I may go wax it now. She is still in nice shape!
This is how I like her:
Ha, thanks. I used wheel acid, its purple and you must be very careful with it. I used it on the intake runners and the valve cover only. I washed the rest with purple power/super clean. Then hit it with a Son of a Gun type product and let it bake in the sun.
Str8 Home built
dam dude very clean as motor how the hell you get it that clean..lol... ive being trying to get my motor htat clean..lol... very good job keep it up dude.lol
1. Is this the same procedure for the 3.2?
2. Does the tranny fluid leak out constant or just a little and stop?
3. Is it better to just unbolt the fans and leave em put, or take em out together with the rad?
no, but mine happened to fall apart when I did the radiator so I had to replace it anyways. ohh yea, DO NOT buy a Murrays radiator cap if you decide to buy a new one. NEVER buy a Murrays anything
You are gonna need a 10mm socket/rachet, a set of pliers, screw driver(philips and flat head), few rags, catch pan to collect old coolant. I forgot the size of wrench you need to take off the coolant temp sensor... Thats what I can think of now....
Replacement radiator in with no problems...thanks for the help and informative posts! Oh and to add to the list of tools above you will need a 12mm wrench for the bleed nut.
'13 Hyundai Sonata
deej0121
experience with radiator from radiator barn???
I noticed that a couple of folks said they bought radiators from radiator barn. Just wanted to see what your experience was? They are a LOT cheaper than other parts stores & ACURA, at least by a factor of 2!! Have you gotten good service out of your radiators? Thanks much in advance!!
Just wanted to say a great big THANK YOU to this forum. I've been here countless times to find solutions to the problems that have arisen w/ my wife's 98' 2.5 TL. I always find useful information and I know I should have registered long ago to say THANKS ... YOU GUYS ARE GR8!!
Muchos Gracias as well for the 'radiator barn' link. Got mine ordered and shipped for less than a hundred bucks.
Extra-special BIG THANKS and Muchos Gracias specifically for 5point9Limited for such a great post. You've inspired me to save some $$ and do it myself (ish ;o).
I'm planning in tackling this next Saturday... 10-6-12. I'll let you know how it goes.
Oh yeah... did I say "Thanks"?
"Radiator Barn" rocks! Ordered Sunday night and UPS is delivering today (tuesday). Now I get to look at it for 4 days until making my DIY-ish attempt. Wish me luck, say a prayer, keep your fingers crossed for me. I'm gonna need all the help I can get.
Thanks again for this mucho helpful thread!
Thanks Mandy. Got-er-done with just a lil' blood shed for the cause... tight tolerances for big hammy hands like mine ;o). No pics but thanks again to all who contributed to this thread.
btw... the temp sensor is 15/16.
4th Gear
This is great wright up! my 96 3.2TL just started to over heat and loose heat at idle too! got a Koyorad radiator for $120 at 1800-Radiator, is Koyorad a good brand? I'm thinking about flushing the whole cooling system, does any one know where is the engine coolant drain valve is? Thanks!
