1996 Acura TL 3.2 ABS
Old 01-24-2011, 09:11 PM
uhenry1's Avatar
Hello,
1996 Acura TL 3.2 ABS with 118,000. I hope someone could help me with my ABS. I got the code for ABS 1-0 code (pump motor overrun) after I replace ABS MODULATOR. I would appreciate if someone tell me what to do and resolve these codes.
Thanks,
Henry
Old 01-25-2011, 08:54 AM
tempetom's Avatar
I assume they go away by themselves. I replaced my modulator recently but didn't bother to check for codes. At least the damned ABS light went out.
Old 02-10-2012, 07:59 PM
6th Gear
Richyrich1516's Avatar
Did you ever figure out how to get rid of the 1-0 code?
Old 02-10-2012, 08:00 PM
6th Gear
I have the 1-0 and am not sure if I need to replace the modulator or just the pump. Any ideas?
Old 03-04-2012, 11:18 AM
6th Gear
Remove the ABS B2 (15 A) fuse in the under-hood fuse/relay box for at least three seconds to erase the ABS control
unit's memory.
mada51589
05-03-2022 08:54 PM
kmarqueling
10-03-2015 01:14 AM
Mike Bertram
09-10-2015 09:27 AM
asahrts
09-04-2015 05:55 PM
Stu2414
4G TL Problems & Fixes
08-30-2015 07:30 PM
Quick Reply: 1996 Acura TL 3.2 ABS
