96 2.5TL O2 sensor question.. - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 04-28-2011, 09:26 PM   #1
Registered Member
Question 96 2.5TL O2 sensor question..
Looking at buying a 96 2.5 with low mileage (85K) but it's been running with a bad O2 sensor for about two years now. Should I be worried? The owner says it idles smooth and gets good mileage but I'm concerned if this could have damaged the engine in any way. Thanks in advance for any info!
slats is offline   Reply With Quote
Old 04-28-2011, 10:12 PM   #2
Registered Member
Before the catalyst O2 or after the catalyst O2? If its before the catalyst then you are probably looking at a bad catalyst.
tmnhs81 is offline   Reply With Quote
Old 04-28-2011, 11:34 PM   #3
Registered Member
Not sure yet. Hoping not the one before cause I know a cat can be pricey. I just didn't know if a bad sensor would cause the engine to foul up from running too rich/lean.
Old 05-05-2011, 11:00 PM   #4
Registered Member
I don't think it can "hurt" the engine. Once its fixed it should be fine. Especially if it runs nice already.
RockAboutBaby is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
TPMS Compatibility? RobbDizzle 2G RL Tires, Wheels & Suspension 5 10-15-2015 12:16 PM
'04 TL Drive Cycle? ? ! samson_420 3G TL Problems & Fixes 5 10-08-2015 02:47 AM
Misfire DTC and TSB 03-033 question thegipper Third Generation TL (2004-2008) 5 09-28-2015 02:01 PM
Check Emissions CEL hrothgar02 Second Generation RDX (2013+) 1 09-28-2015 12:08 PM
Need help place P1129,p0134,p2279 prbori 3G TL Problems & Fixes 1 09-27-2015 02:37 AM
Tags
02, 1996, 1998, 25, 25tl, 96, acura, have, location, o2, oxygen, rear, sensor, sensors, tl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
