What parts from 91-95 legend bolt on or directly replace our tl?
Old 11-06-2009, 04:16 PM
  #41
bwallace530's Avatar
I got the whole type II manifold for 48.5 buck i will put picks up in a bit but shit that took me 4 hours todo at the junk yard to much work i have no clue how to put it on mine tho i ripped and just tore away at it till it was off but i did not damage the manifold at all....
Old 11-06-2009, 04:26 PM
  #42
https://acurazine.com/forums/picture...ictureid=22359
https://acurazine.com/forums/picture...ictureid=22358
https://acurazine.com/forums/picture...ictureid=22356
Old 11-06-2009, 04:27 PM
  #43
the brake stuff would not come off so i said screw it and found the type too.
Old 11-06-2009, 06:18 PM
  #44
I pulled off the strut bar too but didnt take it with me i new i should of.
Old 11-06-2009, 07:54 PM
  #45
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
Originally Posted by TLin401
You cannot remove the front rotors yourself.
If they are the same as the 1G TL you need a press to take the rotor off.
So if that is the case, you will need the whole driveshaft.
I believe for the calipers you need a 10mm and 12mm
that only applies to the 2.5TL... the 3.2TL rotors aren't hub over rotor... just rotor with the holding screws...
Old 11-06-2009, 08:09 PM
  #46
damn all i needed to remove was those dang screws. how do you remove the calipers they were a bitch they would not budge at all and the rotors where all rusted so would it just be better to just us the calipers and buy some new rotors for the legend. and can you paint them with some type of spray paint.
I got all the manifold off of the legend and its not that bad just got some carbon on it how should i go about removing it. I live in an apartment complex moved last summer not that much room to work with either.
Old 11-06-2009, 11:11 PM
  #47
'13 Hyundai Sonata
TLin401's Avatar
Damn you Acura!
I would just get new rotors then.
If you want to spray paint the calipers, yes you can paint them.
You can use either caliper paint or engine paint. You just have to do really good prep work so that the paint sticks to the caliper.
Old 11-06-2009, 11:13 PM
  #48
'13 Hyundai Sonata
TLin401's Avatar
Here you go...
Old 11-06-2009, 11:28 PM
  #49
desired_speeds's Avatar
what tools will be need to remove to rotors and calipers?
14mm wrench or socket/ratchet for the calipers and lines themselves and a 17mm wrench or ratchet to remove the brackets. The 17mm is a bit harder as it's torqued to 80ft/lbs so you will have to use your breaker bars or another wrench for more leverage.
nope
lol...
Old 11-07-2009, 11:31 AM
  #50
does any one want the bottom half of the intake i really do not want to put the whole thing on my car i just want the intake manifold.
The gasket on the manifold is 81.00 for our car the 3.2 tl now that is the exactly the same gasket for the type II.
Im using engine degreaser right now and carbon is really stuck on there i was thinking about taking to it the car wash and pressure washing the manifold.
I would like the get it glass beaded but i have no clue where in chico does it and how much it would cost.
Old 11-07-2009, 12:23 PM
  #51
Im taking the manifold to North State Machine Shop to get it glass beaded for 40 bucks will be done monday. Then im getting the manifold gasket then some time either next weekend for the weekend after that im going to put it in my tl. Im hoping that i will give a noticalbe increase in power.
I was wondering before i do all this will my car still pass emissions???
Old 11-07-2009, 07:20 PM
  #52
大日本帝国
Go90go's Avatar
Yes, it will pass as long as you still have the EGR in place. A pressure washer won't do much, you have to scrape the buildup out. Check the pictures in my thread with the scraper taking out a chunk of carbon.
~Cheers~
Old 11-08-2009, 03:48 AM
  #53
I took it to a machine shop and they are washing drying and glass beading it so that it will look all new again.
Old 11-16-2009, 10:07 PM
  #54
pro_found973.2TL's Avatar
i use to own a legend. recently it got totaled in an accident i had and now i got a 97 3.2 tl premium package and all. anyways, i kno that with going from a type 1 to a type 2 intake manifold on a legend we had to block off the pair valve...is this also true with our tl's?? also just as a side note i took the k&n sri and the weapon-r cold air box i had on my legend and switched it over to the tl and it fits just fine.
Old 11-17-2009, 01:15 AM
  #55
no pair valve on G1 TLs.
Old 11-17-2009, 01:18 AM
  #56
wtf, the bottom half is the same on the tl... All intake manifold gaskets are the same for for the C32, whether its type I, type II, etc. Use a wire brush and a shitload of carb and brake cleaner to get the carbon off. But glass beading is prolly faster.
Old 05-28-2016, 11:36 PM
  #57
3rd Gear
Saavs1233's Avatar
Can you use the manual transmission to do a manual conversion on the TL from an acura legend?
csmeance
09-10-2018 09:15 AM
james357
02-13-2016 02:37 PM
lland
10-04-2015 04:47 PM
DUECE_DXJ
09-24-2015 04:54 PM
darksky
09-05-2015 03:11 AM
Quick Reply: What parts from 91-95 legend bolt on or directly replace our tl?
