DIY: convert Fog Light into DRL's
#81
I actually did this mod, just as described. The 1st part. From what I can tell, no difference. Red wire (blue stripe) out of its harness to ignition wire (big thick wire), connect and enjoy. Also, some of you should check with your local laws. It is illegal in most states to have more than 4 bulbs (projecting forward) from the front end of your vehicle. When the highs are on, you essentially have four lights on, the lows (left and right) and the second filament of the bulb on (another two lights). With the fogs that would make 6 front facing lights projecting forward. Good luck!
#82
#87
'13 Hyundai Sonata
I have another idea for the fogs turning on and shutting off by themselves. I just have to stop being so lazy and do it. I have the wire all together and is just a matter of installing and that's it.
#93
'13 Hyundai Sonata
Wait a minute...
You did this on a 2.5 with this method!?!?
I tried it and went over it 3 times and it was right but didn't work. I don't understand
#94
yeah...it works flawlessly... I just followed the instructions precisely along with the detailed pictures... I would take some pics for you but its a bit annoying to remove the steering cover....the 6 screws was a bitch to unscrew without a mirror.
but yeah. pull out the RED wire with Blue stripe from the lights\signal connector and tap it with a piece of wire.
Then open the bottom and IMPORTANT: remove the GREEN connector and leave it alone.
Then remove the blue connector and tap the thick yellow wire with the wire that you tapped from the top.
reconnect everything and it should work.
#97
Default
#98
'13 Hyundai Sonata
The need for that is that some of the guys on here drive in a lot of places with little to no light. So with highs and the fogs on they get a ton of light.
#99
Hello everyone, first post.
Just want to say: Love this mod, thank you tmnhs81 and Mandy. You guys are geniuses.
Also, for any people who have not started and are confused about parts (I know I was) you need:
-Wrench or something to disconnect your battery, really be careful not to electrocute and kill yourself like I almost did by dropping the wrench and creating a connection between the two terminals
-Phillips screwdriver
-Wire cutters/scissors
-18 gauge wire (other gauge wire like 16 gauge would probably work, 18 gauge is just what I bought)
-22-16 gauge mid-line tap wire connectors (also named quick splice wire connectors) for splicing into the red/blue wire click
-18-14 gauge mid-line tap wire connectors for splicing into the thick yellow wire click
-electrical tape
-electrical tape
#100
cgray526
This prompted me to get my fog lights working. There was a grounging issue with the new style with one lead. Got it fixed and I think im gonna have to try this soon.
#102
cgray526
P.S. your mailbox is full
#104
I wanted to do this for the longest time and still cannot make myself... I do have a quick question though; do USDM TLs have DRLs that come on whether you want it or not? I was under the impression that DRLs are not required in the states like they are in Canada. I'm just asking because it would useless for me to do this if the normal DRLs would stay on along with the fogs.
#109
Im sorry but im new to this i want to make my fogs work with just the button itself i want them to turn on as i press the button for them no matter if my headlights are off?Would this DIY work on mine i know not the first one but what about the second one? Help please
#110
98 3.2 Flamenco Black
#111
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
