What fits, Sizes, Offsets, tested!!
Old 11-11-2014, 11:22 PM
KenB350z's Avatar
20x10 +40F 275/40r20 (flush)
20x10.5 +25R 315/35r20 (it fits, but may stick out a bit)
Size:  69.8 KBName:  DSC_0427_zps84fdfceb.jpg
Size:  58.6 KBName:  DSC_0412_zps796eaae0.jpg
Size:  67.4 KBName:  DSC_0217_zpsa65d315c.jpg
Size:  94.1 KBName:  DSC_0273_zps8ace87e4.jpg
Size:  104.9 KBName:  DSC_0322_zpsc16ae32c.jpg
Size:  74.8 KBName:  DSC_0341_zpsccdc7bb4.jpg
Size:  62.5 KBName:  DSC_0512_zps9059e1e1.jpg
20x10 +40 275/40r20 (flush)
20x10.5 +25 275/40r20 (may stick out a bit, but more flush then the 315 tire)
Size:  81.0 KBName:  DSC_0257_zps00c5fb74.jpg
Size:  66.0 KBName:  DSC_0256_zps076859c2.jpg
19x8 +35 235/50r19 (sunk in-21mm spacer used)
Size:  81.0 KBName:  IMAG1567_zpsaf18d30b.jpg
Size:  72.0 KBName:  Screenshot_2014-07-25-22-59-591_zps3d72f46b.png
Size:  812.2 KBName:  IMAG1035_1_zps553a64af.jpg
19x9.5 +41 285/40r19 (flush)
Size:  56.5 KBName:  IMAG0053_zps0bd45ae0.jpg
Size:  56.5 KBName:  IMAG0058_zpsfbb7b83f.jpg
17x7.5 + 45 255/50r17 (sunk in like factory lowers about 3inch)
File Type: jpg
The following 3 users liked this post by KenB350z:
kuni808 (03-05-2015), TheWrench116 (03-06-2015), UserAtmosphere (12-12-2014)
Old 02-12-2015, 11:42 PM
KenB350z's Avatar
Another view of the 19x9.5 +41 285/40r19 (flush)
Size:  87.1 KBName:  IMAG1663_zpsoml7n4r5.jpg
Size:  69.6 KBName:  IMAG1647_zpsqqgczy6l.jpg
The following 2 users liked this post by KenB350z:
Old 03-05-2015, 11:43 PM
In 702, 808 in Dreams
kuni808's Avatar
I have a wheel set up i'm thinking of running and i tried searching everywhere and couldn't seem to find an answer.
What do you think of a 18x9.5 +34 offset? Running stock size 235/55/18 tires. Do you think this would sit flush? I didn't want to go bigger cause the tires get more pricey. I'm stock height with the possibility of lowering on Eibach's later.
Any suggestions?
Thanks everyone!
Old 03-06-2015, 12:55 PM
FLETCH
TheWrench116's Avatar
Any suggestions?
Thanks everyone!
stock rim is 7.5 or 8 inch? and you want to put a 9.5 inch for what reason if not to run a wider tire? if your going for looks then just get an 8 inch rim and call it done. it will be cheaper any way. I wouldn't stretch tires to fit big rims. this isn't a civic and your going to have a bad day if you treat it like one.
Old 03-06-2015, 02:58 PM
4th Gear
BlackRDX's Avatar
will a 20x10+45 fit in rear without rubbing suspension or control arm? how about a +25 will it stick out too much?
Old 03-06-2015, 02:59 PM
4th Gear
BlackRDX's Avatar
nice BBK!!!!! HOW MUCH DID THAT COST $
Old 03-06-2015, 03:55 PM
kuni808's Avatar
Very true! I was going to run a 245/45 later down the road. I want to burn up the 235/55s i have on there now. I just hate the way the stocks sit so way in. Drives me nutz. Plus the wheel I like only comes in a 9.5" width and wider. I figure i have the width now and later i'll upgrade the tires to be wider. Just a temporary fit. I may go for a 255 if it fits under the wells without it sticking out. What do you think?
Old 03-06-2015, 05:00 PM
2012wagon's Avatar
LOVE LOVE pic #5, with the 67 in the window. Looks amazing. THose steamrollers look like how X5Ms and X6Ms look from the back.
Old 03-29-2015, 10:05 AM
Bswain321's Avatar
Testing this out. I have a set 19x9.5/10.5 +22 would these fit?
Old 03-31-2015, 01:17 PM
jo.jacques's Avatar
^ That would be a pretty aggressive setup, especially for the rear!
You gonna have to try it and report back
Old 03-31-2015, 03:39 PM
Bswain321's Avatar
I bought then for my type s but trying to sell that. Was just seeing if it worked or was possible. That's all.
Old 04-14-2015, 10:43 AM
MrBlue's Avatar
Here are a few pics with Rohanna RC10s Machine Black 20x9 +25 offset ridin on 255 40s. The bridgestone tires have a section width of 9" so they taper up into the wheel well when compressed. I had to remove the BC rear springs as they wouldn't adjust high enough to get the fenders 1" above the tires i wanted.
Old 04-15-2015, 12:40 AM
KenB350z's Avatar
Ksport Big Brake Kits
Old 04-15-2015, 12:42 AM
KenB350z's Avatar
Haha, that was exactly what I was going for. (That X5 look)
Old 04-15-2015, 12:43 AM
KenB350z's Avatar
Looks good!
coykiam
09-11-2015 03:43 PM
Hau_nguyen91
09-06-2015 12:53 PM
nuldabz
09-03-2015 05:49 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: What fits, Sizes, Offsets, tested!!
