Dropitlow
Old 02-13-2017, 06:08 PM
FLETCH
TheWrench116's Avatar
Dropitlow
so i got the coilovers (by Megan) on last week.... after waiting till 155k miles to do new suspension i wish id have done this a lot sooner.
HOWEVER THE ONLY REASON IT WORKS WELL IS BECAUSE OF MY CUSTOM REAR UPPER CONTROL ARMS. additional $400.00
my camber settings in the rear are .9 degrees factory spec is 1 if it were dropped 2 inches without the custom kit id looked stanced and handle for shit. if you like stance life dont talk to me. i wont like you.
Old 02-15-2017, 06:03 PM
FLETCH
I think it's going to look great with the summer setup
Old 04-04-2017, 03:49 PM
allmotorap2's Avatar
Looks much better! This is how it should of came stock honestly. I have the BC's and couldn't go to low due to the bad camber in the rear.
Old 04-04-2017, 03:50 PM
Old 04-05-2017, 12:35 PM
FLETCH
i got a set of upper adjustable arms made specifically to correct the rear camber issue. I'm able to go as low as i want and still maintain proper geometry.
Old 04-05-2017, 08:16 PM
Definitely jealous. I'm at -3 right in the back 😒
Old 04-07-2017, 11:59 AM
FLETCH
call me and i can help point you in the right direction. im sure the shop that made mine would make another set.
BigHatch (04-27-2017)
Old 04-07-2017, 12:37 PM
hues10's Avatar
Oh yeah Wrench, well I am going to put a set of those Eibach Spring things on, and then whip your car...... Well, it won't touch your car cause you may as well have just built a custom car kit thing by the time you are all done with it. Looks good though, and probably drives even better.
Old 04-13-2017, 12:51 PM
FLETCH
That feeling you get when you quadruple the posted recommended speed For an exit ramp!!!
Old 04-13-2017, 12:55 PM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
15mph off ramp?
Love that first post OP...wit and sarcasm aren't lost on me.
Old 04-14-2017, 08:14 AM
FLETCH
Yeah15 went 60
Old 04-14-2017, 09:08 AM
because, you know...35 is pretty slow for an off ramp but then I did the extrapolation and holy shit 140 would be impressive!
Old 04-15-2017, 08:24 PM
FLETCH
Roads seriously suck around here need to repave the whole damn state.
Old 04-17-2017, 06:21 AM
my neck hurts now :'(
Old 04-17-2017, 09:23 PM
FLETCH
Running that low life
Old 04-17-2017, 10:04 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
Polish them headlights, son!
you can DIY, and it'll make your car look new again!
Old 04-18-2017, 06:16 AM
I love that driveway.
Old 06-14-2017, 07:24 PM
CSmoney28
CSmoney28's Avatar
Just ordered the BC Coilovers, Progress Rear Sway Bar, and Prothane Complet Kit. Any feedback on these products?
Old 06-15-2017, 07:08 AM
BC Racing is a good brand, I'm sure they'll be good.
Progress sway helped on my 3G for cornering.
Prothane...not a fan of going harsh on anything rubber but I'm not sure if that's what they do or just better handling.
Old 06-15-2017, 12:35 PM
FLETCH
If you don't have a means to adjust the rear camber you're going to have a bad time when you drop the car. My Factory camber bolts wouldn't even keep my rear suspension in spec with Factory components at factory height. If you run into issues shoot me a text or phone call.
Old 11-08-2017, 03:50 PM
CSmoney28
CSmoney28's Avatar
I finally got my BC Racing Coilovers & Progress Competition Rear Anti-Sway Bar installed. I put the Anti-Sway Bar at the most aggressive setting and it makes a huge difference. You can really really feel the rear end tighten up. It almost feels like more power is in the rear end now. How long did it take your coil overs to settle? I keep adjusting because at an inch and a half from the top of the adjustment I was scraping. Now I’m at a half inch from the top and I’m good no scraping. But my rear seems to have settled more where it’s flush with the tire and the front is one finger from the tire. When it was scraping both front and rear were tucked. I’ll take picture when the weather clears up.
