Service b1 reset HELP!!!!!!!!!!!!!
Old 06-04-2010, 12:54 AM
aleicgrant's Avatar
for the life of me, I cannot get the service b1 to reset even following the manual. I changed the oil and now 300 miles past. I have turned ignition to on, hit the < > multiple times but nothing ever comes up.
really annoying.
can any kind soul help !!!!!!!!!!!!
Old 06-04-2010, 12:56 AM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
What screen are you on in the MID?
Old 06-04-2010, 01:13 AM
aleicgrant's Avatar
when I turn the ignition to on, the only message I get is the service due B1 and the mileage I am over. I cannot get to any other screen in the display no matter what combination I press for buttons????
Old 06-04-2010, 02:04 PM
ADD
ADD's Avatar
You have to hold the button that is between the <> for about 10 seconds. If you do, you'll get the screen that says reset. All you need to do is scroll to reset and hit the middle button again.
Old 06-04-2010, 02:28 PM
aleicgrant's Avatar
http://www.youtube.com/watch?v=9qdj8q1YoOo
I tried and no go. Here is a video
Old 06-04-2010, 04:01 PM
R*D*X*'s Avatar
1. Turn the ignition switch to ON
2. Select Trip A or Trip B (You can use either one, so if you are using one to record data for something, use the other one to reset the Oil Life Indicator).
3. Press the < or > button repeatedly until the oil life is displayed.
4. Press and hold the Select/Reset button for 10 seconds. The Multi-Information Display will ask for a confirmation.
•a. If you are sure you want to reset the display, press the Select/Reset button for 10 seconds again. (This is the part omitted from the manual.)
•b. If you do not want to reset the display, press the < or > button to select "Cancel"
Old 06-04-2010, 04:04 PM
R*D*X*'s Avatar
I think the oil indicator should be showing first before you could reset it
Old 06-04-2010, 05:37 PM
ADD
ADD's Avatar
+1...if you search this site, you'll find info re: oil life reset.
Old 06-04-2010, 06:15 PM
aleicgrant's Avatar
Ok guys I'm not on crack. The cancel doesn't work. I can't get to a or b either so what in gods name am I doing wrong.
Old 06-04-2010, 06:17 PM
aleicgrant's Avatar
And I asssume you select a or b using the dash brightness stick?
Old 06-04-2010, 06:22 PM
YVRTSX's Avatar
You should be able to toggle through using the Select/Reset button as well to move from the A and B trip odometer to the oil life display.
I've found in the past that if a warning is displayed, I've had to press the Select/Reset button a couple of time to get past the "nag screen", and then can cycle through A, B and Oil life.
EDIT: Might be the < button you need to push multiple times...
Old 06-04-2010, 06:36 PM
aleicgrant's Avatar
Guys tried every combo and no joy. Will take it to the stealership and hope they can help.
I appreciate the assistance from everyone on this
Old 06-04-2010, 08:52 PM
R*D*X*'s Avatar
This might be too late but i'm still going to post this video ....This video is for honda crv, but it's almost the same, just hold the odometer stck for 10 secs...http://www.youtube.com/watch?v=pmcts7K0Xd8
Old 06-04-2010, 09:31 PM
aleicgrant's Avatar
Appreciate another suggestion.... Again no joy
Old 06-02-2013, 03:39 PM
lawpage17's Avatar
The last posted video helped me. just changed the oil on my 07 acura tl-s and didnt know you had to press and hold for 15 secs after the service soon a1. Thanks
Mike734
12-10-2021 01:25 PM
08KBP_VA
10-22-2019 01:55 PM
Skirmich
10-01-2015 12:59 PM
thegipper
09-28-2015 01:01 PM
Froid
09-27-2015 06:16 PM
Quick Reply: Service b1 reset HELP!!!!!!!!!!!!!
