PO847 - 3rd Clutch Transmission Fluid Pressure Switch Circuit Short B
Old 02-07-2017, 07:42 AM
FreshMeat's Avatar
Yesterday while driving the Check Engine Light and drive letter "D" was flashing. I plugged in my code reader and P0847 came up. I saw an older post from 2010 about this issue. Does anyone know where the sensor is located? I am going to order a sensor on RockAuto today. Does anyone know if this is the correct sensor? More Information for PA CARGO 98927B
Old 02-07-2017, 07:55 AM
Received 16,260 Likes on 11,971 Posts
Looks like a pressure switch!
on the Acura TL, the pressure switches can be found if you take off the drivers side wheel. they'll be right in your face on the transmission
Old 02-07-2017, 08:02 AM
FreshMeat's Avatar
Thanks!, I will have to take a look tonight.
Old 02-07-2017, 08:56 AM
FreshMeat's Avatar
I think I found it in the manual. Looks very straight forward.
justnspace (02-07-2017)
Old 02-07-2017, 09:05 AM
awesome that you found that!
it doesnt say to take the wheel off, so it may be in a different position than the TL's. but still in the same general area!
good luck!
Old 02-07-2017, 09:13 AM
Received 8,579 Likes on 6,628 Posts
I'd stick to OEM
Old 02-08-2017, 08:26 AM
OhRDX's Avatar
I've had to mess with all these switches.
I believe this one is on the front of the trans wich is facing the front of the vehicle. Take the under tray off, drivers side, should be a few inches up facing the back of the bumper. Pretty easy to get to. Switches are about $25 from company I can't remember name of but can be found many places online.
Mine had a broken wire, check that first.
Old 08-14-2021, 12:29 PM
5th Gear
Junior87's Avatar
good luck!
I took wheel off and can’t see it so that’s a negative friends
Old 08-14-2021, 12:31 PM
5th Gear
Junior87's Avatar
but I ain’t the best at this so I could just be missing it but I’m gonna find it anyway gotta replace the same sensor p0847
Old 08-14-2021, 12:50 PM
5th Gear
Junior87's Avatar
P0847 under air filter !!
Old 08-14-2021, 02:27 PM
CSmoney28
CSmoney28's Avatar
Thumbs up
Glad, you were able to find it!
Junior87 (08-14-2021)
Old 08-14-2021, 03:11 PM
5th Gear
Junior87's Avatar
thanks now I just gotta get the right part Napa gave me the wrong one so now ,let the hunt begin
Old 08-14-2021, 03:23 PM
DaIll1's Avatar
Maybe this will helphttps://www.acurapartsforless.com/v-...ensor-solenoid
Old 08-14-2021, 03:27 PM
5th Gear
Junior87's Avatar
Originally Posted by DaIll1
thank a ton I’m on it !
