Console Armrest Cover Tearing/Delamination - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 07-03-2010, 02:53 PM   #1
haole kama'a-ina
737 Jock's Avatar
The RDX center armrest cover has had bubbles and/or been tearing.
The original part was 83423-STK-A01ZB for gray and 83423-STK-A01ZA for black. If you are getting yours replaced be aware the original parts are still available.
However, Acura has revised the part with a new part number. Revision means they have developed a fix. The new part numbers are 83423-STK-A03ZB for gray and 83423-STK-A02ZA for black. Make sure you get the new parts.
If you are out of warranty, the gray one is available at internet Acura dealers for only about $18 to $22. The black one is much more (about $70). So far no one has been able to explain why.
Will post a replacement DIY when I get the part.
737 Jock is offline   Reply With Quote
The Following User Says Thank You to 737 Jock For This Useful Post:
Lucky52 (08-21-2014)
Old 07-05-2010, 08:56 PM   #2
not an SUV ...a Big Hatch
BigHatch's Avatar
I had the beginings of bubbles on the center armrest and passengers arm rest. Not as bad as these pics though. They replaced them under warranty.
BigHatch is offline   Reply With Quote
Old 07-08-2010, 09:59 PM   #3
Registered Member
vrflyer's Avatar
Yeah, I just had mine replaced by dealer not too long ago as well. The bubbling wasn't that bad either, but it happened form night to day.
vrflyer is offline   Reply With Quote
Old 07-09-2010, 06:35 PM   #4
Registered Member
I have a stain on my cover and the car is only a month old. This just made me rethink about cleaning it with liquid solvents.
Omnious is offline   Reply With Quote
Old 07-12-2010, 05:54 PM   #5
Registered Member
phoward_15's Avatar
Wow this is crazy. Thanks for the heads up 737 Jock and the advice to fix it. I hope this never happens to me though.
phoward_15 is offline   Reply With Quote
Old 07-29-2010, 01:05 PM   #6
Registered Member
good to know.
I have the same think on my drivers arm rest and the dealer wants me to pay for it.
rosalesmonterordx is offline   Reply With Quote
Old 07-30-2010, 11:39 AM   #7
haole kama'a-ina
737 Jock's Avatar
Replacing the Armrest Cover
First, be sure you get the new part number. Here is the new gray armrest cover:
You will need a #2 cross-tip screwdriver. Make sure you retain all screws and don't mix them up. I use labeled baggies.
Move the driver seat down and back; ie, out of the way. Open the console/armrest door. It will remain in the full open position.
With a #2 cross-tip screwdriver, remove the three base retaining screws (red arrows):
There are 7 plastic clips holding the base to the cover and the hinge is sandwiched in between the base and cover. First you must remove the base by prying out the seven plastic clips. Their locations behind the base are circled in yellow below. Start at the top front corner GENTLY prying out the first clip, then work along the top edge, loosening as you go. The base will catch on the lock hooks -- slide the hooks back to free it. Pry down along the rear edge and the base should come free:
Here is the inside of the base, showing the top front corner clip. This is the only clip that is on the base (the other 6 clips are on the cover):
The base will be re-used. Set it aside:
Now you can remove the cover from the hinge. Remove the 2 screws (red arrows) at the top of the hinge:
Tilt the lid closed enough to lift off the cover. The hinge spring will return it to upright:
You must remove the lock assembly from the old cover and attach it to the new one. Remove the 9 screws from the lock assembly (yellow circles). Tilt the lock assembly up and out from under the plastic tabs on the cover (red arrows):
Here is the lock assembly ready to be installed into the new cover. You can also see the other six plastic clips inside the new cover:
Now just reverse the previous steps.
IMPORTANT; the metal screws will be installed in plastic. Turn each screw down till the head contacts the plastic, then snug it a little. DO NOT OVER TIGHTEN
Tilt the lock assembly in and under the tabs on the new cover. Work it gently into place and install the 9 screws.
Tilt the hinge enough to install the new cover. Work it into place until the screw holes line up. It has guide pins which will help align it. Install the 2 hinge attachment screws.
Now try closing the lid. It should close and latch. If it doesn't latch, recheck your lock assembly install. It may rattle a little -- that's OK -- the base has bumpers which will fix that.
Now open again and note where the plastic clips are on the cover and base. Work the base into position and slip it over the lock hooks so that the hooks protrude through the slots in the base.
Support the cover from behind and press the clips in, pushing at the clip locations.
Install the 3 base retaining screws. Ask wife to come see her new armrest:
The Following 7 Users Say Thank You to 737 Jock For This Useful Post:
dr427 (11-04-2012), HEAVY_RL (10-07-2012), Lucky52 (08-21-2014), Mainframe Guy (06-28-2014), SinCity (08-20-2013), spineman (03-31-2015), zerogravity (05-29-2012)
Old 07-30-2010, 11:59 AM   #8
Registered Member
vrflyer's Avatar
Color looks way off (I realize this is due to being new).
Old 08-04-2010, 01:58 PM   #9
Registered Member
Warranty cover my door arm rest.
Dealer is installing it today.
Old 08-04-2010, 07:22 PM   #10
Registered Member
ottoman101's Avatar
I haven't had this problem, but do you think it might be caused by the sunlight through the sunroof? I always close the visor because I'm paranoid that the direct sunlight will damage the leather interior.
ottoman101 is offline   Reply With Quote
Old 08-05-2010, 03:02 PM   #11
Registered Member
its a possibility ...I closed mine too and I have also the foil windshield sunshade as well ...but this is have been a HOT summer in the DC area....
Old 08-06-2010, 11:32 AM   #12
XIS
Lizard King
XIS's Avatar
It could be the sun, but I doubt it is the heat... Doesn't get much hotter that where I live... 100 in the garage! 110 outside! Mine (2007) still looks like new.
XIS is offline   Reply With Quote
Old 08-09-2010, 03:58 AM   #13
Registered Member
kmillard92's Avatar
Was happening on my center and drivers armrest...Cerritos Acura replaced under 'Goodwill' warranty with the new parts, but if it happens again they said I'm SOL.
kmillard92 is offline   Reply With Quote
Old 02-11-2011, 09:01 PM   #14
2008 Acura RDX
wspy's Avatar
Please note that the new part numbers mentioned above are listed for the '09 and up models. If you search for the '07 ,'08 you'll get the older part number!
wspy is offline   Reply With Quote
Old 05-24-2011, 06:30 AM   #15
Registered Member
Our 2007 RDX cover is torn. The problem is it is tan and all I can find is black and grey. Did Acura seriously stop making parts for a 4 year old car?
merlot is offline   Reply With Quote
Old 05-24-2011, 09:20 AM   #16
haole kama'a-ina
737 Jock's Avatar
From 2007 to 2011, the RDX interiors come in either Black or Taupe.
Black leather takes the Black console armrest cover.
Taupe leather takes the Gray console armrest cover.
Look at the "Acura Showroom Interior Interactive" and you can see that the console cover is gray with the taupe seats.
Old 05-24-2011, 09:40 AM   #17
Registered Member
Yeah, my wife just showed me that after I posted. According to Wikipedia, Taupe is a dark grayish-brown color. Meh - looks tan to me. At least I know what to order now.
Old 08-03-2011, 01:12 AM   #18
Registered Member
sebringap1's Avatar
What online store do you guys recommend purchasing the leather cover from?
sebringap1 is offline   Reply With Quote
The Following User Says Thank You to sebringap1 For This Useful Post:
vaprea (05-18-2012)
Old 08-29-2011, 03:02 PM   #19
2008 Acura RDX
wspy's Avatar
Acurapartswarehouse.com
Old 09-15-2011, 10:22 AM   #20
Registered Member
737 Jock can you please advice where you bought the 83423-STK-A03ZB from? Looking on the Internet I'm only getting prices as high as 65$ and above.
Thanks!
LoDRpR is offline   Reply With Quote
Old 09-19-2011, 10:37 AM   #21
Registered Member
DRR98's Avatar
Redline Goods...Great leather, more color choices...
See more about it in this thread...
http://rdx.acurazine.com/forums/show...9#post13242659
DRR98 is offline   Reply With Quote
Old 09-29-2011, 12:49 PM   #22
Registered Member
rohit.'s Avatar
This has happened to my '07 as well! Thanks for the write-up
rohit. is offline   Reply With Quote
Old 12-10-2011, 07:15 PM   #23
Registered Member
thanks a lot for the instructions, took me 30 minutes. Bought it for $80 shipped. It starting coming apart right after warranty. You are right, they've upgraded the leather, its more durable.
russianDude is offline   Reply With Quote
Old 01-16-2012, 05:47 PM   #24
Registered Member
phoward_15's Avatar
In case any of you don't feel like taking this on yourself, I took my RDX in for B1 service today and mentioned the armrest and they said they would switch it out no questions asked. I only have 3 months left on my warranty so wanted to make sure I had everything fixed along with the rear driver-side seat latch which was rattling (another common problem I've read on this forum).
Old 05-18-2012, 10:36 AM   #25
New Member
Just want to show my appreciation for this thread. My console cover is in really rough shape at 55,000 miles. Completely unacceptable. But, thanks to this community I'm ordering the part and will fix it myself. Rock on, Acurazine.
Blogan is offline   Reply With Quote
Old 05-18-2012, 12:07 PM   #26
2008 Acura RDX
wspy's Avatar
Das what we do
Old 05-23-2012, 03:20 PM   #27
New Member
great write-up, my wife's RDX is also bubbling up, i'm assuming we are out of warranty (at 58k) and truth be told i've never set foot in an acura dealership, but i think with this info even a clutz like myself can fix it once i order the replacement.
timofeu is offline   Reply With Quote
Old 05-29-2012, 05:28 PM   #28
Registered Member
I'm am so glad that I was able to find this. I hve ordered the replacement part and I am looking forward to completing this DIY. I will def check back in wth the results. Thank You
tfs1975 is offline   Reply With Quote
Old 05-29-2012, 06:51 PM   #29
Registered Member
No homo but you are my hero thank for posting this up I am out of warranty and thought this was going to be expensive.
zerogravity is offline   Reply With Quote
Old 06-04-2012, 02:17 PM   #30
Registered Member
I received the part and completed the install on Thursday night. It took about all of 20 minutes and looks great. My GF is extremely happy with the results. Thank's for the step by step DIY.
Old 07-20-2012, 03:56 PM   #31
New Member
center console armrest "bubbles"
I have the same issue with my 2006 RL, tried talking to the dealer and acura, both UNRESPONSIVE, even telling me "That's not a defect". Call this number at Acura Customer care and let them know it IS a defect and we are tired of hearing it is not our problem. My Rl is is great condition, 85,000 miles and perfect...except for this DEFECT.
800 382-2238 x115188
anthony will answer, flood Acura Customer care with calls and let's get this fixed. spend $50,000+ for a car and this is what happens?
DanCast is offline   Reply With Quote
Old 07-27-2012, 02:50 PM   #32
New Member
Help please
To 737 Jock-
My center console finally tore after all the bubbling. I did look online with the part # you provided, but the cheapeast gray one I found was $$75. Can you help me out and point me in the right direction in regards to websites?
Thanks much!
Sdentino is offline   Reply With Quote
Old 08-05-2012, 08:23 PM   #33
At the Clarmont Lounge
Thanks for the write up/pics!!
JT Money is offline   Reply With Quote
Old 09-18-2012, 02:18 PM   #34
New Member
Where did you find it on the Internet for that price? The cheapest price I found was about $73.00
Jmhughes is offline   Reply With Quote
Old 09-18-2012, 09:38 PM   #35
Registered Member
Quote:
Unless you have a time machine to go back to 2010 (when it was posted), good luck. They've all equalized the prices.
TruckerBomb is offline   Reply With Quote
Old 10-07-2012, 04:09 PM   #36
Registered Member
Saw this in looking for a replacement for my torn one.
They are made out of leather and pretty reasonable priced if you are willing to install yourself. I messaged them and asked if they would do other colors for the stitching and will update when the reply.
http://www.ebay.com/itm/2007-2012-Ac...721b62&vxp=mtr
EZZZZY1 is offline   Reply With Quote
The Following User Says Thank You to EZZZZY1 For This Useful Post:
Old 10-07-2012, 06:04 PM   #37
Registered Member
Just heard back and they can do really any color stitching it just takes 3-4 days longer.
Old 10-26-2012, 04:55 PM   #38
Registered Member
So because my armrest was tearing and I am outside of warranty I went ahead and picked up one from Autotrimming on Ebay. Spoke to them over the phone first and was confident with them and the work they do. I also went ahead and purchased a shift boot with red stitching to match. They dont make them for the RDX but they do make them for the RSX. I plan on modding it a bit and making it work.
It takes a few minutes to take the arm rest off and then about another 30 to remove all the old staples from the OEM cover. Then it took me about 45 minutes to stretch the leather around the console and re-staple it. I used small 1/4" staples in a smaller staple gun that I have and they seemed to work well. In a few spots that where the staple was able to penetrate the plastic you can feel a little bump under the padding and leather but nothing that will poke through or be uncomfortable.
When its done it looks great! I would say deffinitly spend some extra time really pulling and streatching the leather so that its tight. You also want to make sure that the lines end up being straight when its all done.
This is what the armrest looks like, I will post up again when I get the shift boot put on this weekend.
dr427 (11-04-2012)
Old 10-26-2012, 07:45 PM   #39
Registered Member
DateTSX's Avatar
that looks great! Are the CF pieces from Ebay?
DateTSX is offline   Reply With Quote
Old 10-26-2012, 08:14 PM   #40
Registered Member
It is. I have had it on for a few years now, everyone digs it.
http://www.ebay.com/itm/Acura-RDX-07...99ba9e&vxp=mtr
vaprea (10-26-2012)
Thread Thread Starter Forum Replies Last Post
My personal comparison between 3G TL and TLX (mostly negative side) mlody Fifth Generation TLX (2015+) 68 04-29-2016 10:08 AM
FS: Black rear center console garnish, 3.2 VTEC IM cover and gasket InFaMouSLink Car Parts for Sale 6 10-27-2015 07:52 PM
Front Door Courtesy Lights Replacement Covers BIGxRED Fourth Generation TL (2009-2014) 13 10-19-2015 11:47 PM
SOLD: 3g TL OEM Coin Holder ROWDY621 Car Parts for Sale 1 09-30-2015 04:20 PM
Driver Fan blower change mode by itself hashbrown Fourth Generation TL (2009-2014) 2 09-29-2015 01:13 PM
Tags
2007, 83423stka02za, 83423stka02zb, 83423stka03zb, acura, armrest, console, cover, jock, lid, mdx, parts, rdx, replace, replacement
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
