k23a1-k24a2 head (RBB tsx)
Old 05-22-2016, 12:01 PM
Haré romel's Avatar
Hi, my ultimate major work.
Bottom stock.
I ll have to go dyno, run so lean now.
Pictures speak for itself:
2009 RDX, 720cc, flashpro, RV6, ZDX flow, skunk2 intake manifold, water intercooler, ARP stud, BC cams, ferrea valve retainer, k24a2 head ported.
Attached Thumbnails k23a1-k24a2 head (RBB tsx)-20160405_185834-mod-1.jpg   k23a1-k24a2 head (RBB tsx)-20160428_131001-mod-2.jpg   k23a1-k24a2 head (RBB tsx)-20160428_131014-mod-3.jpg   k23a1-k24a2 head (RBB tsx)-20160504_165243-mod-4.jpg   k23a1-k24a2 head (RBB tsx)-20160504_170003-mod-5.jpg
k23a1-k24a2 head (RBB tsx)-20160505_115325-mod-6.jpg   k23a1-k24a2 head (RBB tsx)-20160506_165154-mod-7.jpg   k23a1-k24a2 head (RBB tsx)-20160506_170019-mod-8.jpg   k23a1-k24a2 head (RBB tsx)-20160514_132042-mod-9.jpg   k23a1-k24a2 head (RBB tsx)-20160514_131926-mod-10.jpg
Old 05-23-2016, 11:09 AM
Slow98teg's Avatar
Do you have any coolant going to the manifold anymore? Might not hold up long. Good luck on the dyno
Old 05-25-2016, 06:36 PM
Haré romel's Avatar
Of course, external inlet, it can be seen circled in the picture. if I don t do that it could melt manifold.
Old 05-26-2016, 07:42 AM
Slow98teg's Avatar
Oh ok I see it now. Missed it the first time. Are you running a 25* vtc gear or 50*?
Old 05-26-2016, 04:59 PM
Haré romel's Avatar
RBC 50 vtc gear
Old 06-10-2016, 07:38 PM
KenB350z's Avatar
Bottom stock.
Nice!
Old 06-11-2016, 03:43 AM
DDTsx06's Avatar
no write up on how to do this? was it hard to do? did everything mount up correctly. Nice job btw!
Old 06-13-2016, 10:20 PM
Haré romel's Avatar
Pictures speak for itself, major work was the exhaust manifold (look circle in the picture), close water port, drill to move bottom bolt, adapt external inlet npt fitting. also connection to return all external port to water pump inlet (not to radiator for continue recirculation), oil cap below water intercooler (I ll have to remove for oil change) , but the complete head fit perfectly (you have to use all tsx head part, cover, water port,...... )
THX...
Old 06-13-2016, 10:23 PM
Haré romel's Avatar
Originally Posted by KenB350z
Nice!
Thx...
You help me respond some question to do this, thanks again.
Old 09-10-2016, 02:41 PM
Haré romel's Avatar
Hi all, I have problem with the exhaust manifold, it broke inside after coolant liquiq by one hose fault, this manifold is very delicate with the temp. I go for aftermarket exhaust manifold. I recommend not do exhaust manifold modification.
Old 09-10-2016, 07:15 PM
KenB350z's Avatar
Other the that, how was the k20 head?
Old 09-22-2016, 08:09 AM
FLETCH
TheWrench116's Avatar
what is with the turbo compressor wheel? thats not stock is it?
Old 09-25-2016, 10:34 AM
Haré romel's Avatar
Excellent, more hp at less boost, high reving fast, i tuned by myself to proof if all is good, but :-( exhaust manifold damage.
Old 09-25-2016, 11:01 AM
Haré romel's Avatar
Yes, that's not stock, I did turbo upgrade with other company, +70 hp stock housing. There s +100 modifying housing but you have to adapt some parts. I didn t want do modification.
Now, i have big problem, probably i mount t3 turbo as kenb.
Old 10-15-2016, 05:37 PM
Haré romel's Avatar
:-) Some parts:
- Garrett To4e turbo oil cooled ( Let s see, later i go for ballbearing water-oil cooled gtx30)
- Cast iron manifold
- tial wastegate 38mm
- oil feed kit
- oil drain kit
Attached Thumbnails k23a1-k24a2 head (RBB tsx)-20160926_131507_resized.jpg   k23a1-k24a2 head (RBB tsx)-20160928_172842_resized.jpg
Old 10-15-2016, 05:44 PM
Haré romel's Avatar
Begin work, I hope fast spool necessary for heavy rdx.
Old 10-16-2016, 08:26 PM
KenB350z's Avatar
Old 10-30-2016, 05:48 PM
Haré romel's Avatar
still working...
Attached Thumbnails k23a1-k24a2 head (RBB tsx)-20161029_161316_resized.jpg   k23a1-k24a2 head (RBB tsx)-20161029_161330_resized.jpg
Old 11-02-2016, 01:15 PM
KenB350z's Avatar
Yeah buddy!
Old 11-05-2016, 12:58 PM
KenB350z's Avatar
How is it coming along?
Old 12-06-2016, 11:08 PM
Haré romel's Avatar
Sorry, I was traveling, but I'm done.
Looks same as before
It accelerates fast, feel great, without tuning, I'm just proving reliability, now. But,
turbo load slower 1800rpm oem vs 2500 rpm to4e journal, but excellent after loading.
The external wastegate sounds too much outside, I will connect it to downpipe.
I sometimes have p2263 code, I do not know if I have a bad connection or I need to tune.
I ll check that.
But overall I love it.
Attached Thumbnails k23a1-k24a2 head (RBB tsx)-20161120_220718_resized.jpg   k23a1-k24a2 head (RBB tsx)-20161120_220811_resized.jpg   k23a1-k24a2 head (RBB tsx)-20161120_220834_resized.jpg   k23a1-k24a2 head (RBB tsx)-20161120_221016_resized.jpg
Old 12-13-2016, 05:57 PM
WTF?
bluecarbonfiber's Avatar
Makes you wonder with the new civic type r that has a turbo if there is any compatible parts with it
Old 12-15-2016, 08:42 PM
KenB350z's Avatar
I ll check that.
Nice! P2263 code, haha; who cares!! You can kill just about anything on the road now. The code is because of the turbo. I had that, but not really worried about it.. Dude PM me your location, would love to meet up and check out your setup!
Old 12-18-2016, 12:45 PM
Haré romel's Avatar
haha, I don t worried about because this don t affect boost control, but I ll like hondata disable that code (p2263 - p2261), there re many people with oem turbo that have code them.
Thank you, it would be a good idea to meet, but I'll move out soon, so I'll let you know.
Old 03-24-2017, 12:01 AM
Haré romel's Avatar
Hi guys, external boost control and flashpro low value boost control resolve p2261 code but I ve check engine light on present just p2263 now.
feel good just at 9lb
DRR98 (04-03-2017)
Old 03-28-2017, 04:00 PM
KenB350z's Avatar
https://www.youtube.com/watch?v=M9Y1EjqWa2A
Nice, I should have my K20 head in the machine shop this week for a valve job. Can't wait, sounds good!
Old 04-02-2017, 08:10 PM
Haré romel's Avatar
Cool br, post your mod when you do it.
Old 07-24-2017, 09:59 PM
Haré romel's Avatar
Bye stock exhaust, welcome 3" complete custom magnaflow exhaust, no sound with straight through, excellent....
Attached Thumbnails k23a1-k24a2 head (RBB tsx)-20170619-stock.jpg   k23a1-k24a2 head (RBB tsx)-20170619-custom.jpg   k23a1-k24a2 head (RBB tsx)-20170619-custom2.jpg   k23a1-k24a2 head (RBB tsx)-20170619-custom1.jpg
Old 07-25-2017, 08:32 AM
KenB350z's Avatar
Yo, looks pretty dope! Can they make a duplicate?
Old 07-25-2017, 08:28 PM
Haré romel's Avatar
No, was custom make, I bought magnaflow mufflers and tips and he did everything.
Old 09-16-2017, 11:10 PM
KenB350z's Avatar
I will have to say, with the traditional VTEC head this thing revs effortlessly!
Old 09-18-2017, 11:11 PM
Haré romel's Avatar
mmm, I dont think so, i m with 11 psi, street fuel, vtec point 7300rpm, 7600 revlimit now it feel very well, i m planning 13 to 15 psi with street fuel to see if engine knock resist. Dont want pay race fuel. i dont have bb turbo (t3 to4e), i would like to install gtx28 gen2 to see if check engine off or gtx30 gen2 for full perfomance.
Cam adv, ign... are very different, i had to work hard in this map. I recommend to work hard in your tuned. Remember you have now factory cam and before you had bc cam, Me bc cam a1, now bc cam a2.
Old 09-19-2017, 06:18 AM
KenB350z's Avatar
I was able to drive on the old map. If you don't run enough boost, you will get a check engine light. Yeah, the aftermarket cams have a more aggressive profile as far as the lobes go.
noraz123
05-15-2020 01:29 PM
beaglepower
08-15-2016 07:27 PM
Quick Reply: k23a1-k24a2 head (RBB tsx)
