blow thru MAF?
I haven't seen anyone here post about it. Aside from letting you run an atmospheric BOV without issues, I don't see the advantage...plus on this car I think it would be a bitch to install unless you convert to a front-mount I/C.
There shouldn't be any innate problems in doing a blow-through setup, other than the sensor itself appears to max out early in a 3" pipe.
If you are making under 275whp or so, the stock MAF in a 3" pipe will skate right under the 5v limits.
We've had to step up to a 3.5" MAF housing diameter to get enough room for 300whp.
fixauto4b
02-03-2021 01:22 PM
jimihendrix465
12-19-2015 09:21 AM
