Bulb replacement guide
Old 07-25-2007, 01:52 PM
sasair's Avatar
2007 ACURA RDX
Low beam headlamp
HID-D2S
High beam headlamp
9005 or HB3
Parking light
1157A
Front turn signal
1157A
Rear turn signal
7440
Tail light
168
7443
Stop light
7443
High mount stop light
921
Fog/Driving light
H11-55W
License plate
168
Back up light
7440
Front sidemarker
168
Rear sidemarker
194
Map light
2825
Dome light
DE3175
Step/Courtesy light
194
Trunk/Cargo area
168
Old 07-26-2007, 04:45 PM
El Chulo...
VeNeNo's Avatar
thanks, you are the man sasair...!
Old 04-23-2008, 05:51 PM
6th Gear
aleh314's Avatar
thanks this is so helpful
i found my license plate led model from here
Old 04-24-2008, 11:41 AM
phoward_15's Avatar
Is it possible to replace the tail lights with LED lights or will that damage something? If so what type of LED lights should one get?
Old 04-25-2008, 10:56 AM
cwepruk's Avatar
You can get LED tails of the same fit, so they go right in. I bought LED's once, but they only lasted a whole week (both of them).
You also have to keep in mind, signal lights need a resistor to work right since LED's have much less resistance. I'm not an expert on it, but keep it in mind and do a bit of research before buying something.
Old 04-25-2008, 11:18 AM
brizey's Avatar
There is another thread about LED's. I have switched out all of my interiors for LED's. That thread has all the part numbers and where I bought them. Working fine for 9 months or so.
Old 04-30-2008, 06:05 PM
playa4real's Avatar
Anyone know what bulbs are in the vanity lights?
Old 04-30-2008, 09:00 PM
brizey's Avatar
Edit: I did not change the vanity lights or the console light.
Old 04-30-2008, 09:12 PM
playa4real's Avatar
The vanity mirror bulbs are 8161L festoon bulbs rated at 12V and 2 watts
Old 06-27-2008, 04:15 PM
Ukrainian RDX
Azzie's Avatar
http://www.sylvania.com/ConsumerProd...lacementGuide/
might be also useful
Old 12-08-2009, 07:29 PM
BLACURA SUVND9L's Avatar
LED Brake Lights
I hope this hasn't been asked before, sorry if it has, but:
I know you can replace the bulb for the upper rear hatch brake light with an LED direct replacement, but I really like the look of LED strip lights as brake lights on other vehicles. Has anyone looked into this as a replacement, maybe for the whole housing, instead of 1 bulb in the middle, a strip of LED's across the whole thing?
Old 04-20-2010, 08:07 AM
....OK, howabout the Low-beams, I know they're HID D-2S's but what temperature are the factory bulbs. I'm trying to figure out what color (temp) to get fogs in. I hear most factory HID's are around 4000k-5000k, but I want to match the fogs to my Factory low-beams as possible. Anybody else installed HID fogs that match pretty close? Pics would be helpful. Thanks in advance!
Do you think these would work in the 4500k range?
Old 04-20-2010, 02:57 PM
2008 Acura RDX
wspy's Avatar
4500k is the correct range but the bulb is a H11 !!
Old 05-20-2010, 03:56 PM
vash337's Avatar
subscribed. are the DRL's just the high beams at a low setting or are they a small wedge bulb?
Old 05-21-2010, 05:38 AM
2008 Acura RDX
wspy's Avatar
Originally Posted by vash337
subscribed. The DRL's are just the high beams at a low setting!
^^ This!
Old 09-19-2010, 06:53 AM
JOE COOL's Avatar
light bulb in back seat burnt out again.
i just replaced it less then a year ago.
anybody else?
Old 10-21-2010, 12:29 AM
3rd Gear
Hometown China's Avatar
front middle storage compartment light
anyone know the bulb size and i how i can get to the light bulb to change it...? hmmm
Old 10-25-2010, 06:32 PM
PM me if you need a reply
InfamousJamous's Avatar
Excellent thread, thank you! I have a base model and assume the lows are already HID. Can someone please confirm?
Going to get a 3000k HID kit for the fogs soon to get that JDM look not to mention better performance in foggy conditions.
Old 10-26-2010, 01:22 PM
After doing some researching, I've concluded that HID lows are standard
Old 10-27-2010, 03:44 AM
jacksonlan33's Avatar
this saved me hours of research thanks.
Old 12-02-2010, 09:32 PM
JCRDX11's Avatar
Thanks for the info..just ordered 3k HID kit because of this guide!
Old 01-23-2017, 05:26 AM
6th Gear
pvtplum1290's Avatar
anyone know the bulb replacement for the arm rest compartment 07 rdx ??
oo7spy
06-19-2023 12:48 AM
hedzup
1G RL (1996-2004)
06-29-2016 08:07 AM
EE4Life
09-11-2015 10:02 PM
brjones9
09-03-2015 07:30 PM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
Quick Reply: Bulb replacement guide
