what would happen if I don't replace the catalytic converter? - AcuraZine - Acura Enthusiast Community
Thread Tools Search this Thread
Old 10-13-2008, 01:03 PM   #1
Registered Member
Mine just went totally dead for the past 3weeks and I cost too damn much to replace a new one. Would it ultimately harm the car's engine or intake system if I don't fix it in long run? Only negative I was told by a local mechannic was that it will just cause the engine light to stay on and won't past inspection, otherwise it won't do any harm to the car.
devasta is offline   Reply With Quote
Old 10-13-2008, 01:06 PM   #2
666 Speed
artbran's Avatar
your MPG will suffer greatly
-either gut the cat and get a spark plug defouler on it or an O2 simulator from www.o2sim.com
-get a high flow cat and put it in
-or get a test/race pipe and use the same thing as in suggestion #1
artbran is offline   Reply With Quote
Old 10-14-2008, 04:44 PM   #3
Registered Member
bRunCL's Avatar
How do you know the converter is bad? Are you just going by the light, or did your mechanic actually test the cat?
bRunCL is offline   Reply With Quote
Old 10-23-2008, 12:45 AM   #4
'99 2.3 CL
iansanderson's Avatar
Quote:
+1. Did he perform a backpressure test on it? What codes are being registered? Is the car driving sluggishly?
btw, it is always helpful to put the year and model of you car in your signature
anyways, coming from a BMW, failing catalytic converters were the norm around 100K miles. They typically fail from lack of maintenance, driving with the Check Engine light on or physical damage from running over something. The least expensive option to fix the problem would be having a muffler shop weld in a replacement catalytic converter. A good local shop shouldn't charge anymore than $45-50 for this.
Here is a weld-in model for a 97 3.0 non CA emissions for $247
http://www.car-sound.com/02product/d...versal=99334HM
and here is a direct fit (no welding), same car for $450
http://www.car-sound.com/02product/d...irectfit=27402
I would be 100% certain that is the prob before you do this however. I don't recall Honda's having issues with catalytic converters, but ya never know.
iansanderson is offline   Reply With Quote
Old 10-23-2008, 01:32 PM   #5
Registered Member
I was just told by my mechanic that my catalytic converter is whacked. Something is loose inside, and it rattles badly in between 1500 and 3000 RPM - right in speed limit range! When I step on it and drive faster, the RPMs go up, and the rattle disappears - this is not good incentive to drive safely.
Anyway, my friendly neighborhood ACURA dealer (aka "The Devil People") quoted me almost $3000 just for the part! That seems REALLY unreasonable to me, since I have seen them on eBay (and elsewhere online) for cheap. I think the ones on eBay may be universal - is there anything wrong with getting a universal Catalytic Converter, or should I stick with genuine(ly overpriced) ACURA parts?
I just replaced my transmission a couple of months ago, and don't need another bill like this with the car being just a few months out of warranty:
2003 Acrua TL Type-S A-Spec
125 000 km's
I really love the car when it is working well, but it sure has a LOT of issues, and every issue costs a fortune to fix.
7chips is offline   Reply With Quote
Old 10-23-2008, 02:29 PM   #6
cool breeze
Yurhomieblaze's Avatar
http://cgi.ebay.com/ebaymotors/Easte...2em118Q2el1247
i replaced my cat with the one in the auction it was for a 96 accord 2.2 and it works good, passed visual and tailpipe emission tests(after failing 3 times with old cat/exhaust)
good direct fit, bolted right in, no welding. it was also reasonably price compared to new dealer cats and did the same job.
Yurhomieblaze is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
4th gen. 2012 TL TORQUE CONVERTER issue w/6sp auto. orkoTL 4G TL Problems & Fixes 95 02-14-2017 01:27 AM
SOLD: 07-08 ATLP Type S Quads Non-Res and 04-08 RV6 V3 Long Tube J-pipe IIDXholic Car Parts for Sale 23 10-08-2015 08:53 AM
The time has Come.. My car started dropped to 2nd. Skirmich Second Generation TL (1999-2003) 37 09-15-2015 07:41 PM
A/C and Head light problem theinsvnity 2G TL Problems & Fixes 2 09-10-2015 11:22 PM
Recommended Exhaust Shop?? jpm3071 NY/NJ 1 09-07-2015 09:25 AM
Tags
acura, cat, catalytic, converter, dont, ep3, fix, gut, happen, no, replace, replacement, replacing, rsx, welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
