Looking for amp wire diagram for factory bose
Alight so the last time i searched for the diagram like half a year ago i found the link to the diagram sheet. Well the search system didnt really help me this time and im stuck at a dead end.
I got the deck installed, but with the wires still connecting to the Bose Fatory Speakers, i dont hear jack.
So im asking you guys on AZ if anyone here has the diagram or knows what wires connect to what at the Amp in the trunk.
(For future and search reference: its a 97 Acura 3.0cl with Bose premium sound.)
Thanks.
Thanks.
~[τΏτ]~
Audio Unit Terminals
│Cavity│Wire...│Connects to...................│
│A1....│YEL....│Output (Right front +)........│
│A2....│WHT....│Output (L Front +)............│
│A3....│RED/BLK│Lights-on signal..............│
│A4....│WHT/YEL│Constant power................│
│A5....│WHT/RED│ACC (Main stereo power supply)│
│A6....│YEL/WHT│Stereo amplifier (power)......│
│A7....│RED....│Output (L rear +).............│
│A8....│BLU....│Output (R rear +).............│
│A9....│BRN....│Output (R front -)............│
│A10...│ORN....│Output (L front -)............│
│A11...│-------│Not Used......................│
│A12...│-------│Not Used (97).................│
│......│WHT/BLU│Radio remote switch (98)......│
│A13...│-------│Not Used......................│
│A14...│BLK....│Ground....................... │
│A15...│GRN....│Output (L rear -).............│
│A16...│BLK....│Output (R rear -).............│
│A1 │A2 │A3 │A4 │▒╔═══╗▒│A5 │A6 │A7 │A8 │
│A9 │A10│A11│▒▒▒│A12│A13│▒▒▒│A14│A15│A16│
Stereo Amplifier Terminals
│B1....│BRN/BLK│Passenger's door speaker - ...│
│......│.......│Right tweeter - ..............│
│B2....│RED/GRN│Passenger's door speaker + ...│
│......│.......│Right tweeter + ..............│
│B3....│WHT/YEL│Constant Power................│
│B4....│-------│Not Used......................│
│B5....│YEL/WHT│Power (with readio switch ON).│
│B6....│-------│..............................│
│B7....│BLK....│Input (R rear -)..............│
│B8....│BRN....│Input (R front -).............│
│B9....│GRN....│Input (L rear-)...............│
│B10...│ORN....│Input (L front -).............│
│B11...│-------│Not Used......................│
│B12...│BLU/YEL│Left rear speaker +...........│
│B13...│GRY/WHT│Left rear speaker -...........│
│B14...│BRN/WHT│Right rear speaker +..........│
│B15...│RED/YEL│Right rear speaker -..........│
│B16...│BLK....│Ground (G533).................│
│B17...│LT GRN.│Ground (speaker)..............│
│B18...│-------│Not Used......................│
│B19...│-------│Not Used......................│
│B20...│BLU....│Input (R rear +)..............│
│B21...│YEL....│Input (R front +).............│
│B22...│RED....│Input (L rear +)..............│
│B23...│WHT....│Input (L front +).............│
│B24...│-------│Not Used......................│
│B25...│GRY/BLK│Driver's door speaker - ......│
│......│.......│Left tweeter - ...............│
│B26...│BLU/GRN│Driver's door speaker + ......│
│......│.......│Left tweeter + ...............│
│B1 │B2 │B3 │B4 │B5 │B6 │B7 │B8 │B9 │B10│B11│B12│B13│
│B14│B15│B16│B17│B18│B19│B20│B21│B22│B23│B24│B25│B 26│
Thanks^
but here is the one i found couple days after i posted it.
To bypass the amp, you got to connect the wires from audio unit to the speakers itself.
like Audio unit right front: you connect to: Right front speaker
Also, the polarity of (+) and (-)
hope this helps someone.
Do you know where i can find specs for 2005 acura rl bose amp wiring diagram?
2005 RL Bose wiring schematics
I am trying to hook up some Kicker brand 1" tweeters in a 2005 RL that is equipped with the Bose stereo system. I would like to piggyback the factory door tweeters. Can anybody tell me if this will cause a problem with the factory amp? ie incorrect impedance???
Also, I located a wiring sheet on the forum for an older RL w/ Bose however it doesn't seem to be the same as a 2005. I would like to connect the tweeters in the truck @ the amp. Therefore I need to know the wire colors for the door tweeters. Could somebody provide a 2005 Bose amp wiring diagram?
Thank you very much.
3rd Gear
I have a 1998 CL 3.0 and i have been dealing with this headache with the factory amp. I purchased a "Premium Sound Line Output Converter" Model ISVE61. I was told that it would turn on the factory amp. I followed the wiring diagram and installed the knew head unit. STILL NO SOUND.. !!! Does any one know what the next step would be. I still would like to use the factory amp for my car, I dont want to by-pass it.
InFaMouSLink
10-30-2015 09:43 AM
SUPRMN84
10-07-2015 09:46 PM
