Whack Windshield Wipers ...WELP!!
Old 10-26-2010, 09:48 AM
TAco23's Avatar
haha, just I know it is spelled with and H.
Anyways, here in the chicagoland area we were suppose to have the worst storm in 70 years. Like always the meteorologists dont know shiznit. But it did rain a little. While using my wipers they were slamming against my hood when I would go slow or stopped, but then when I got going they would hit off the side of the car, but not hit the hood.
What the F is going on. Is there a way to minimize the wipers path of travel? Or some way to tweak them. It happens with either delay or low or high. 97 CL 3.0
Old 10-26-2010, 10:16 AM
DaInFaMMuS1's Avatar
You need to remove them, clean off the threads, and put the bolts back on and torque them down n u should be good
Old 10-26-2010, 10:25 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,410 Likes on 3,022 Posts
You have to readjust them, loosen the bolt that holds them, and reseat them.
Old 10-26-2010, 11:15 AM
97'CL2.2's Avatar
i had the EXACT same problem....it was speed dependant, almost as if the wind resistance played a role in it. if i went on the freeway they would almost wipe off the windshield, and at a dead stop they would slam the plastic guard.
what you need to do is first take your wiper arms off. then take the plastic guard off and remove the whole wiper assembly, this is trickey due to the awkward access area but be patient it will come. your problem lies in the rods which connect the motor to the arms. if you look at the ends there are white nylon "sockets" that are supposto snap into place over top the "ball" portion on both ends. these nylon sockets wear out and since you cannot buy just the sockets to my knowledge you have to order them. no sweat they are like $25 for both rods from OEMacuraparts.com. replace both rods and your wipers will work as new. there is a thread i got all this info from somwhere on here, if you do a search it may yield more results. good luck
Old 10-26-2010, 01:33 PM
Eband27's Avatar
Had the same problem. The teflon balljoints in the link system are used up, u need to change them.
Check this out, i have some pics: https://acurazine.com/forums/showthr...ghlight=wipers
Old 10-26-2010, 06:09 PM
97'CL2.2's Avatar
ah yes you were the one i pmed for the info i needed...thanks alot man it worked like a charm
Old 10-27-2010, 08:19 AM
TAco23's Avatar
I dont care what they say about you, you are the bestest. I will try to check out this issue this weekend. I appreciate the links, the advice and the quick response.
Old 10-27-2010, 11:31 AM
Eband27's Avatar
lol?
TheMuffinMan
06-02-2022 07:11 AM
csmeance
09-10-2018 09:15 AM
bluetl04
08-16-2016 02:49 PM
blacktsxwagon
10-27-2015 10:12 PM
rhdune16
09-28-2015 11:31 AM
Quick Reply: Whack Windshield Wipers ...WELP!!
