motor sound?
Old 08-27-2007, 05:08 PM
zinx's Avatar
motor sound?
i noticed that my cl is making mortor spinning sound somewhat like supercharger spooling sound after my tune up. and no, i dont have supercharger
it happens whenever i step on the gas pedal in gears. i assume it could be my alternator??
any ideas??
Old 08-27-2007, 05:17 PM
One custom CL
SupraManAG's Avatar
its a posibility. check your belts. anything loose?
Old 08-28-2007, 03:09 AM
maiyumi_chan's Avatar
wow coincidence, my CL is making the exact same noise as you described. =/ i think its the belts... im going to change the serpentine and a/c belt. maybe its that. *shrugs* could you please lmk what yours turns out to be? tia!
Old 08-28-2007, 03:21 AM
macsta's Avatar
i have the same problem buts its my clutch.
Old 08-28-2007, 09:37 AM
where is....
AznX TL's Avatar
i think its a pretty normal noise, i had this noise happen after the dealership changed my belts, and my friend's accord sounds the same.
Old 08-28-2007, 10:46 AM
labelhunter's Avatar
I had this problem. It was only when using my AC. It was my compressor going bad for my ac.
Old 08-28-2007, 01:24 PM
gotguinness?'s Avatar
I think i might have this problem as well, what happens when you hit the clutch?
Old 08-28-2007, 02:16 PM
hawaiioahukailua
uncodoper's Avatar
check your belt tension. i noticed that if the p/s belt is too tight the pump will start to make a noise like what you're hearing. it usually only happens on the p/s pumps with smaller pullies (civic, integras, etc) but it happens. i'd have to say belt tension.
also, just make sure whoever did your tune up didn't leave anything off or loose.
if it only happened after your tune up then it has to be something that was touched.
Old 08-28-2007, 07:00 PM
ahh, yeah my a/c compressor has a small leak in it. bleh. well, just order a shit load of maintenance parts (a/c compressor,dryer,coil,and belts). i'll see how that goes. =(
Old 08-28-2007, 11:21 PM
macsta's Avatar
the noise stops.
Old 08-29-2007, 10:56 AM
the noise stops.
I see, do your RPM's seem to be dropping quicker than usual??
Old 08-30-2007, 01:13 AM
macsta's Avatar
nopee
mlody
12-04-2019 02:11 PM
blacktsxwagon
10-27-2015 10:12 PM
juanrl
09-29-2015 03:25 AM
xsilverhawkx
09-28-2015 06:51 PM
Quick Reply: motor sound?
