99 acura cl bogging problems
I jus bought this car from a friend. He had the timing belt and water pump recently changed. He told me that he was driving the car fast and everything was fine then out of nowhere it starts to bog. He hasn't driven the car since till i bought it from him. I start up the car no cel or anything runs fine and i changed out the ignition switch since that was one of the problems it had. I start driving it home and then it throws a cel. Its bogs then stalls out. I start it up again and drive for couple minutes then same thing again. I remove the ground battery cable to reset the ecu then started back up like a champ with no cel. I was almost home till it did the same thing again and finally had to tow it since it didnt wanna start up. I didnt touch the car for a day then i started it today and worked like nothing happen. I checked the distributor and everything seemed to be fine. Is there anyyhing else i should look for? It only throws the cel when driving and the cars warmed up. I wanna get this thing on the road already lol. I dont think its a main relay since the fuel pump turns on. Im thinking ignitor but could be so much other things. Lmk if anyone has some suggestions on what i can do
Wish there was a way to check what that CEL meant
First it threw an eld code and found that wire was disconnected and plugged it back in. Then it threw the tdc code p1361 which is located in the distributor. I ordered a distributor so hopefully it gets in bybthe end of this week
