Shaking when I accelerate. 1997 CL 5 speed
Hello, I'm a new member here and was looking for some assistance with an issue I have with my recently bought 97 CL. It seems like when I let go of the gas and then press it again, whether I'm shifting gears or if I'm just cruising in 5th, the car sometimes sputters and shakes, and refuses to accelerate. Strange thing is that when I press the gas harder, something feels like it kicks in and the car stops shaking and I accelerate really fast. I feel like it might be the fuel filter, but I'm not sure. I've been reading a lot of people having shaking problems due to a broken axle, but its just strange that when I press the gas all the way in it snaps out of the shaking and takes off.
I'd really appreciate some feedback with this. Thank you and I'm glad to be part of this community.
tipsycoma (01-17-2012)
I'll keep posted. Thanks everyone for the suggestions.
MMkay.
spark plugs and wires takes 10-15 minutes on these. wouldn't hurt either. although to me it seems more like a fuel delivery problem rather than ignition.
you should try and reproduce the problem at a standstill as well; if you are at a low rpm;low speed and in 5th gear;that will cause the same feeling. a vibration because the engine is struggling to keep up with motor? Is this your first manual car ?
Nothing yet. I've been trying to pinpoint what it could be so I don't have to spend money on things that won't help fix it.
I really don't think its the fuel filter, because when I'm idling and I press and let go of the gas, it doesn't sputter or shake. It's only when I'm moving. Not only that, but when it DOES start sputtering and shaking, if I press the gas in more, it all of a sudden snaps out of the shaking and takes off like VTEC kicked in or something. Super weird. I'm thinking it might be the sparkplugs or distributor cap. I don't think it's fuel related though, because if it was, it would do the same sputtering and shaking even when I'm not moving and pressing the gas, right?
Oh and it only happens sometimes. Maybe once or twice in 30 minutes.
MMkay.
not necessarily; if it was the ignition as you think it is ; it would happen regardless; the change or issue comes as the motor is under load..right? Well, that's all i can really help with over the internet. You might want to actually look into some diys to save you some cash; especially if you haven't done a tune up..it would help whether it fixes the problem or not. So that's one of those situations that you're investing money not spending..good luck.
You're probably going to laugh, but I just remembered my car hadn't had a gas cap on it since I bought it. I was thinking maybe some dirt or too much air got into the tank and the fuel pressure wasn't there, so I went to the autoparts and bought a gas cap and some fuel injector cleaner.
The car drives noticeably smoother, the gas pedal is much stiffer, and it doesn't shake anymore when I let go of the gas and press it again. I am going to keep driving it around the block just to make sure this isn't placebo effect.
Guess I'll install the fuel filter and see what happens.
u dam fool!! no gas cap was a pretty relevant detail to mention! however, now that u got the pressure and the safety in ur tank, now time to check the filter, prolly could have a lil issue there now that we kno u had to cap this whole time! ur CEL come on too?
JAPCARLUVR
Have a similar issue in my 99 CL 3.o auto. Accelerating on the low end I often get a fluttering feeling in the engine, never if I am on the hwy. My research has pointed me in the direction of a bad torque converter.
09-25-2015 06:14 PM
