Rear Washer Camber "trick" w/ pics
Old 10-11-2005, 11:49 PM
Insert Sarcasm Here
Smalls's Avatar
Another write up DIY for fixing the rear camber with new bolts and washers, this time with pictures.
This comes from a Honda Accord forum, but as we all know, the suspension is the same for the CL, credit for write up goes to cokinut.
Here we go....
The New Bolts
New bolts (left) Old bolts (right) and washers
Perfect example on why you NEED a camber kit!
These are the bolts you need to remove and replace
New bolts and washers installed
Look how straight my rear tires are
How many washers should you put in? I think a good estimate is assuming each washer equals 0.25 degrees of adjustment. The acutal amount of camber on the wheel shown above is -0.24 Be sure to go get an alignment after you put on your camber kit! Just because your camber is straight, your tires may still wear because of incorrect toe. I had 50% tread on my tires, after my camber kit install, a week past and the tires were down to the wires because the toe was off.
Bubble between the lines is good.
Old 10-11-2005, 11:57 PM
Insert Sarcasm Here
Smalls's Avatar
Something else
Originally Posted by ghost_masterCL
Here's a little extra info:
you can only do 3 or so washers ont eh stock bolts, but if you plan on fixing more than 1 degree (about 3 washers) get longer bolts. these kind: 4 M10 x 1.25 x 50mm long bolts
good washers to use: SAE 3/8" (9,5 mm)
Old 10-12-2005, 02:29 PM
...is now Carbon Fiber'd
hybridnrg's Avatar
thank you sir! this will help!
Old 10-13-2005, 01:22 AM
First EVER K24 Turbo CL
starboy2nv's Avatar
excellent info!
Old 10-13-2005, 02:38 AM
klepto's Avatar
is there anything else you have to d/c other than just those two bolts?
Old 10-13-2005, 09:42 PM
Insert Sarcasm Here
Smalls's Avatar
^nope
I did this today to my CL. My only advise, make sure you get the 60mm bolt if you need anything more than three washers, I barley got three to fit on the stock washer. Get fender washers, not cut washers (almost got the wrong ones) and do ONE bolt at a time, I found this to be easier. Dont forget to jack the suspension up!
Bolt = 10mm x 1.25 pitch x 60mm
Washer = 3/8 Fender washer
Old 10-14-2005, 12:45 AM
Si says "shut the fuk up"
$peed])emon's Avatar
so u dont need a camber kit when u do this?
Old 10-14-2005, 01:25 AM
recycledpaper's Avatar
camber is the only car area that confuses me... so let me get this straight, if i were to complete this rear washer camber trick, would i need to get a camber kit for the rear? if not... then good, less money to spend
BTW, i am going to buy a front camber kit, does ONE camber kit offer correction tools for both front wheels? after i install the camber kit, i need an alignment right? thanks... i just need as much clarification as possible, thanks!
Old 10-15-2005, 12:37 AM
Insert Sarcasm Here
Smalls's Avatar
no, this is an alternative to a camber kit for the rear.
recycledpaper, you will need two camber kits. left front and right front.
Old 10-15-2005, 04:51 AM
so what is the main purpose of this trick?
Old 10-15-2005, 08:53 AM
"FROGGYSTYLE"
froggystyle14's Avatar
to keep the back tires from wearing out on the inside....I am doing this Wednesday the 19th so we shall see. SMALLS -- when u had an alignment before the kit, how bad out was yours?? I had mine done with 17's on and they said that it was half degree out. no that i am to 18's would that make it worse and need more washers or should i just start out with 2 and go from there?
Old 10-16-2005, 12:08 PM
Insert Sarcasm Here
Smalls's Avatar
on the alignment before hand,
left rear was -1.2
and my right rear was -1.0.
The proper spec for the rear is -1.0 to 0.0. I applied three washers to the left rear and 2 washers to the right rear, which made the
left rear -0.6
and the right rear -0.8,
both are now within spec.
froggy - If you were told it was a half a degree out (-0.5), that would be right in the middle of the spec, making it good to go. Maybe they meant it was a half a degree out of spec. (-1.5) Becuase if you are -0.5 like they made it sound, you shouldn't need to do this.
Old 10-16-2005, 02:21 PM
klepto's Avatar
can i get these bolts at home depot or do I like gotta goto kragen or something
Old 10-16-2005, 02:25 PM
Insert Sarcasm Here
Smalls's Avatar
yep, got mine from Home Depot
Old 10-20-2005, 01:13 AM
97 2.2cL black
chuckz's Avatar
i also did the trick with the washer and the bolt a while ago. it is the actual kind of camber kit you would get if u purchased a "accord rear camber kit" from ebay. they send u long bolts with many washers. make sure u have two jacks to this. one for the car and one for the suspension. good luck!
Old 10-23-2005, 02:14 PM
wontonjohnny's Avatar
Here we go....
The New Bolts
Not to be a KIA, but using a level is dumb dumb to me. is the ground your parked on horizontally level? i bet if you turned you car around the level readings will now be way off. maybe thats why you had different readings on each tire and had to use 2 washers on one side and 3 on the other side. I would use a framing square.
Old 10-26-2005, 04:05 AM
wilp99's Avatar
that or maybee take it in get it aligned and have them print out the results. instead of gettin out protractors and microscopes and shit.
Old 10-26-2005, 05:50 AM
B A N N E D
ayougo's Avatar
werd but its also 60 dollars and sometimes a waste of money.
Old 10-27-2005, 01:13 AM
wilp99's Avatar
most places will guarantee your alignment for 90 days. take allied tire, i got my car done there for 55$ and they guaranteed it for 90 days. for 90$ they would have guaranteed it for 6 months. i got the 90 day one cause i was goin to put my camber kit on and get it realigned (needed to see which kit i needed according to how far off my shit was) but i got deployed and missed out on my warranty.
Old 10-27-2005, 05:37 PM
Insert Sarcasm Here
Smalls's Avatar
I knew I had to put 2 washers on one side and 3 on the other side becuase I had an alignment read-out in my hands from days earlier. I knew what my specs were and I knew how much adjustment I needed.
Old 10-29-2005, 09:43 PM
teh CL's Avatar
is this the same for 2.2s & 3.0s?
Old 12-29-2005, 04:58 AM
klepto's Avatar
just did this mod today. Just some tips:
-tape the washers together so that they dont move when you try to put them in. Its very hard to get the washers, the control arm and the bolt lined up. They have to be perfectly aligned in order for the bolt to screw it corectly all the way.
-jacking up your rotor so that the arm goes up will help you align up the holes
the first side took me and my friend a good hour or so because we couldnt get the damn bolt to screw in all the way because it wasnt perfectly aligned. After we figured out those two tips above the second side literally took us 10min
Old 01-07-2006, 08:13 PM
Racer510dude's Avatar
They also sell an Ingalls rear camber washer kit for pretty cheap on ebay also.
http://cgi.ebay.com/ebaymotors/Ingal...ayphotohosting
Old 01-08-2006, 01:21 AM
20 bucks for bolts and washers.
Old 02-19-2006, 02:41 PM
M2B4's Avatar
how many washers would i need for a 2 inch drop ? on agx
Old 04-11-2006, 01:08 AM
Ahhhhhhhh
LLWesMan's Avatar
I'll be doing this tommorow, hopefully it all goes well.
Old 04-21-2006, 04:24 AM
ninjaturtle420's Avatar
wait so i need 1 jack to lift the CAR and 1 more jack to compress the shock???? im confused on this
thanks for the help
Old 08-10-2006, 09:25 AM
Land of Pleasant Living
shnee's Avatar
i got 10mm x 60 mm with 1.25 pitch, but the threading only goes about halfway up the bolt.
will this still work, or do i need the threads to go all the way to the head?
i notice the stock bolts are blank at the top, but the ones in the picture are fully threaded
any help?
Old 03-13-2008, 04:42 PM
chinoscl's Avatar
any help?
just noticed this too the bolts i bougth only have thread about half way up
is it still useable?
Old 04-06-2008, 09:52 AM
Ballin' on a budget
Doctorsound's Avatar
thanks for the help
yupp. Put 1 jack under whatever solid jack point you feel comfortable with, place the other under the moving part of the suspension. Reason for two, you'll have to adjust the one under the suspension.
Old 03-27-2009, 10:40 PM
acura2.2cl's Avatar
need help you can see the pic of my car in my profile .my car have 225-40-18 and in 5 months the both rear tires went finish like formula number 1 cars..lol i mean no tread left i like to know what it could be why its eating the tire like this.my tires doesnt look like the one you put on this tread your tire look bad from inside but mine completly finish.plz help me.
Old 03-29-2009, 04:58 PM
acura2.2cl's Avatar
my car have 18'' alloys so can i still put 3 washer in left rear and 2 in right rear?or for the 17" alloys its diffrent?
Old 04-17-2009, 02:37 PM
acura2.2cl's Avatar
hello guys need help i bought bolts and washer for camber trick and the size of washer is 3/8 9.10 and in this diy its says it should be 9.5 mm so can any one tell me what should i do?i cant find 9.5mm
Old 04-17-2009, 02:54 PM
Josh99CL's Avatar
Your rear tires wore down evenly or just the inside/outside/or middle?
Are you lowered at all and with what?
I have no idea why your rear tires would wear down flat and even unless they're just worn out from normal wear.
When you have a camber issue (which the bolt/washer trick is used to fix) it's because the tire isn't even up and down cause one side of the tread to wear faster.
Old 04-18-2009, 05:21 AM
acura2.2cl's Avatar
the left side tire start worn from outer side then completly middle and in.
Old 05-23-2009, 04:29 PM
Newbee's Avatar
does this work with the front? or is there another way?
Old 05-25-2009, 04:13 AM
Newbee's Avatar
anybody? i'm having serious camber issues up front, had to switch my front and rear tires so i can last a little bit longer. Does this trick work with the front?
Old 05-25-2009, 01:34 PM
Myxomatosis's Avatar
thank you for this write up, I never quite understood it till now, this is a must do for me this summer.
Old 05-25-2009, 01:58 PM
f22vtec's Avatar
do u guys think ill need a camber kit in the front with tein s techs? it says 1.7 inch drop i have a 2 finger gap. i might do the washer trick for the back its lowered about 1.4
Old 05-25-2009, 02:05 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
Search man, it doesn't work on the front, you need an adjustable balljoint camber kit
Quick Reply: Rear Washer Camber "trick" w/ pics
