P0401 EGR insufficient flow, Easy fix
Old 05-07-2009, 06:06 PM
Ozzieninja's Avatar
I drive a 97 Acura cl 3.0 and just hit 250,000! My check engine light went on months back spitting the code P0401, thanks to the forums I knew what I had to do but put it off cause I thought it would be long job. Well I had to get my emissions checked and it would fail with this so the time came. Let me say it was cake! I used this link.
http://www.driveaccord.net/PDF/egr_port_clogging.pdf
It seemed intimidating at first cause I had to detach a lot of things but it was pretty self explanatory. I didn't buy a new EGR kit or special drill bit either. I didn't even need a drill, just a few bits and carburetor cleaner. It was like cleaning resin out of a well used pipe. Didn't spend a dime. So if anyone is putting this off or thinking of taking their car to the stealership I'd recommend doing it yourself its simple. No more check engine light and I passed emmisions.
Old 05-07-2009, 06:08 PM
Custom User Title
Gnate's Avatar
nice job!
Old 05-07-2009, 09:03 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
nice, too bad your miles are so high or you could have gotten the free emissions work done
Old 05-07-2009, 09:12 PM
Custom User Title
Gnate's Avatar
3.0's weren't eligible i thought.
Old 05-07-2009, 09:38 PM
Ozzieninja's Avatar
free emissions work...? on a car with 250,000 miles? really?
Old 05-07-2009, 09:55 PM
Custom User Title
Gnate's Avatar
No, he was saying its too bad you have such high mileage and a 3.0. 97 2.2's are allowed free emissions tune ups before i think its 175,000 miles.
Old 05-08-2009, 09:45 AM
Ozzieninja's Avatar
Ha word...I bought the car at 190k for 4000 they guy thought I could put another 15k on it so far I've put 60k on it...I've replaced the motor/track for the passenger window (40 bucks ebay), cleaned the egr (freebie) and replaced all the rotors and pads...which was a bitch since they slide off towards the engine bay, while everything was apart I changed the front bearings too. (bout 300) The dealership wanted something like 2 grand for a break job, pays to do it yourself but the rotors gave me some trouble, still worth it.
Old 05-08-2009, 09:53 AM
Ozzieninja's Avatar
just remembered, I went on a 5 month hiking trip and when I returned my hood latch had rusted shut...20 bucks for a new one on ebay it was a bitch trying to get my hood up lol
Old 05-08-2009, 01:29 PM
(Mid-Atlantic)
the 97's are up to like 150K or something
Old 07-27-2009, 08:25 PM
1stcl:daze1's Avatar
Hey anyone have this DIY, this link, http://www./PDF/egr_port_clogging.pdf ,is not working anymore...thanks appreciate the help !!
Old 08-12-2009, 08:29 PM
jcci's Avatar
https://acurazine.com/forums/2g-tl-1999-2003-98/diy-thermoblok-spacers-install-egr-cleaning-615644/
Man is this forum full of info......gonna have to learn how to step away......
Old 11-16-2009, 12:58 PM
MUCKBOY83's Avatar
hey where do i go on the website to learn how to unclog egr?
Old 11-16-2009, 02:10 PM
less n00bin more g00glin
OttaWacK's Avatar
^^ read and search, there are several posts.
Old 11-18-2009, 12:46 PM
Bagel Bomber
Mach30SiR's Avatar
I have the pdf. PM me your email address if you want.
Old 04-30-2010, 11:12 AM
P0401's Avatar
I know this is an old thread but as you can see by my user nick I have the EGR code on my 97 3.0. I saw some parts on eBay saying it was a permanent fix for the EGR problem and was wondering if that is true. The link above is for a 4 cylinder motor and was wondering how much different is the 3.0 since the pdf link doesn't work any longer
Old 04-30-2010, 04:34 PM
1998 CL 3.0
Polaris573's Avatar
Ignore the part about the spacer install. Unless you want to install them
https://acurazine.com/forums/showthread.php?t=615644
Old 04-30-2010, 06:43 PM
P0401's Avatar
thanks, I don't know what I was thinking but for some reason I was thinking that was a 4 cylinder. Anyhow thanks for he response, now do you happen to have heard of this "permanent fix" thing for the EGR where you will never have this problem again?
Old 05-02-2010, 10:42 PM
P0401's Avatar
I did this fix today and it was allot easier than I expected, the tutorial really helped allot and only took like 30 minutes to complete. My port was totally clogged up but was really easy to clean out with a can of carb cleaner and drill bit. The CEL light is finally off and hopefully it will stay that way for awhile. Thanks everyone for all the help and if anyone is putting off doing this there is no need because it was really simple to do
Old 05-05-2010, 01:44 PM
1998 CL 3.0
Polaris573's Avatar
If I recall correctly acura had some type of insert that was supposed to "permanently fix" the egr flow problem. I think it still occurs even with that though. I've never heard of the ebay item you're talking about and can't find it in a search. Link?
Old 05-15-2010, 02:40 PM
P0401's Avatar
this is the one i was referring to http://cgi.ebay.com/ebaymotors/1997-...Q5fAccessories . the fix is just the sleeve that you are talking about that you drill and insert. from what i have read on here it may help a little but is not a permanent fix like they say. I took mine apart and cleaned everything and fixed mine until next time but it was a very easy fix. I didn't buy the kit I was asking about I just used the instructions on this site to do mine. One thing they forgot to show on here though is they showed the port on the intake but didn't even mention the port on the head that has to be cleaned also. I had to take mine apart twice because of this, I just did the intake and cleared my code and it came back on and I was like what the heck and read and reread the instructions and couldn't think of why it was doing it, so I thought "hey there has to be a port in the head as well that may be clogged" so i took it back apart and yep there was. So i cleaned it the second time and all has been well for over 400 miles so far
Old 05-16-2010, 10:47 AM
5th Gear
homeinsandiego's Avatar
can some one repost the pdf?
Old 05-16-2010, 01:49 PM
1998 CL 3.0
Polaris573's Avatar
Nope, but can you read 5 posts above yours?
Old 05-16-2010, 05:12 PM
5th Gear
What does the spacer kit do?
If I only want to clean the EGR port, do I still need to buy new gaskets.
Old 05-16-2010, 05:42 PM
1998 CL 3.0
Polaris573's Avatar
The thermoblock spacers are optional. They keep the throttle body and intake manifold cooler. You might as well buy new regular throttle body and intake manifold gaskets while you have everything torn apart though. They're not too expensive and you may or may not do damage to your old ones when you take everything apart.
Old 06-13-2010, 03:26 PM
Joshkl's Avatar
link where spacers can be purchased?
Old 06-13-2010, 11:31 PM
P0401's Avatar
http://www.outlawengineering.com/index.html
Old 06-13-2010, 11:55 PM
Joshkl's Avatar
fsho. thanks.
Old 08-23-2010, 07:06 PM
Land of Pleasant Living
shnee's Avatar
just for anyone looking at this, the URL is missing d*ri*ve*acc*or*d .net (without the asterisks, obviously)
damn CEL is on again, 5 years later.
Old 01-25-2011, 02:54 PM
giants200's Avatar
Hi, I have the same P0401 code on my 97 Acura CL 3.0. I have replaced and cleaned the EGR valve and passage, but after 200 miles the check engine light came back on again with the same P0401 code. Anyone can advise what I can do next? Could there be leakage on any other places? Thanks in advance!
Old 03-14-2011, 05:24 PM
4th Gear
BLeague's Avatar
1998 Acura CL 3.0
I was excited to read your post since I got the same code "P 0401" and have been dreading taking care of it. Your pdf link doesn't work anymore. Can you e-mail me and tell me what you did to fix it??
bkl27@hotmail.com
Old 03-15-2011, 09:52 AM
P0401's Avatar
here is a walk through that will give you all the information you need, just no need to do the spacer thing but do everything else https://acurazine.com/forums/showthread.php?t=615644 It doesn't show them cleaning the port inside the block but be sure you clean the one on the intake and the one that corresponds with the intake port on the block as well. i forgot this step and had to redo the whole process. I did this about a year ago and have had absolutely no problems from it again yet
02-25-2020 09:57 AM
pstomps
02-20-2017 03:29 AM
giovane
2G RDX DIY & FAQ
07-08-2016 10:46 PM
mugen_kid
11-13-2015 10:38 PM
09-21-2015 08:44 AM
Quick Reply: P0401 EGR insufficient flow, Easy fix
