DIY - Requests
#121
Originally Posted by arstraub
I need to know how to remove the passenger door panel - my window needs to be fixed and the door handle is also broken.
https://acurazine.com/forums/showthr...ghlight=window
#123
Regional Coordinator
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by Mach30SiR
Just replace the fuel filter on a 3.0 yesterday along with distributor cap, ignition rotor, pcv valve and other easy things.
Should have probably done a DIY for at least the fuel filter but its not that hard. Hardest part is reaching the screws that hold the filter mounting bracket. Anyways if anyone needs some help just let me know.
#124
where is....
Originally Posted by hellifino69n
well i just got done doing it, and ill tell you...
get it done at a shop
cause its a biatch
cause its a biatch
btw can someone do one on changing the bulb on the shifter for the 97.
#126
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by AznX TL
x10000 i even lifted the car to try to change it, couldnt get the metal end to budge.
#127
where is....
It's a #74 bulb, you don't need to unscrew anything, just turn the bulb wire and pull it out.
#128
(Mid-Atlantic)
(Mid-Atlantic)
how do you get to it? i got the arm rest off but i couldnt find where to take out the radio/shifter column screws.
#131
(Mid-Atlantic)
(Mid-Atlantic)
yeah i cant get the middle console right at the shifter off........or dont i need to take that off?
#132
(Mid-Atlantic)
(Mid-Atlantic)
Originally Posted by leetuser
Is there a DIY up for a AEM v2 cold air intake for a 2.3 first gen cl?
#133
where is....
The console that the radio is in? or the piece around the shifter? The plate on the shifter doesn't need to come off
i was under the impression that the whole entire shifter had to come out to get to the bottom to change out the bulb.
#134
(Mid-Atlantic)
(Mid-Atlantic)
hmm can you get to the bulb from here?
#136
Azine's only Punk PFC
Request for cheapo blue climate control mod?
I saw the blue clock mod, and the climate control was discused, but how do you do take it apart? Any insight?
#137
whatever the thing is that keeps the trunklid from falling and chopping me in the collarbone is failing, and I can't tell what the hell to replace ... anyone got a DIY for that :x:
#138
278
Originally Posted by 972.2
somebody should do a tutorial for removing the balance shaft?
http://honda-tech.com/zerothread/1908944
This a pretty good write-up, if this doesnt help then i dunno what will.
#140
Ballin' on a budget
Originally Posted by Damon7
Need a DIY FRONT ROTOR replacement for a 97 CL 2.2
No, but seriously, I'd like to see this too, the last time I went to do my brakes I realized that I wasn't equiped to handle that. Apparently you need a special tool...
#141
(Mid-Atlantic)
(Mid-Atlantic)
https://acurazine.com/forums/showthread.php?t=148107
#143
Originally Posted by yomomsbigpimp
Is there a DIY for projector lights conversion on a 97 cl? I know I've seen some pics on a forum but I can't seem to find them.
#144
(Mid-Atlantic)
(Mid-Atlantic)
#145
DIY REQUEST: TUNE-UP with pictures.....I realize doing a tuneup is a relativiely easy process...but i am not mechanically inclined!!! 98 2.3 with 115,000 miles. I have owned the car since 80k and nothing done to engine besides new clutch. I feel the MPG are not as good as they use to be...
PLEASE DIY for changeing spark plugs, wires, distributer cap, fuel filter and anything else sugguested!! also, should i just pick these items up at autozone??
thanks
thanks
#146
thanks
thanks
#147
come on guys help a guy out with a tune-up cant be hard just let me know exactly how to do it!!
#148
Has anyone removed the rear interior side panels, like the interior door panels, but by the rear seats? Are there any special tricks I should know before I try and possibly tear the panel off?
#149
I found this "1997-1999 SERVICE & BODY REPAIR MANUAL" for Acura CL on ebay. Has anyone tried or heard about it? Is it any good?
http://cgi.ebay.com/ebaymotors/ws/eB...m=370084672319
#150
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
(Mid-Atlantic)
It's only 4 bolts, I believe there was an alternator replacement diy that told how to take it off, but it's 4 bolts and a wiring harness clip, not too hard, I had to take mine off to do my radiator
#153
New headunit with factory Bose???
I did a few searches on installing new head units and have seen many people say they can either use the factory amp with a new head unit or bypass the bose amp very easily, but nobody ever explains how to do this. I found a few pictures of factory radio harness, but still dont see a wire to trigger the factory amp. So i suppose my question is how, if you can, how can you power the factory amp with a new head unit, or how can you easily bypass the factory amp with out running new wires to every speaker? maybe im just being lazy because i dont want to take my car apart for just a few wires, just looking for the easiest possible way or a shortcut
#155
(Mid-Atlantic)
(Mid-Atlantic)
dragon084 has
#156
CL in lawnmower status
^really, i thought he didn't do it
^that was taken from Cheehos's Public Profile as response to when he asked Greg about the swap
here's a thread where Cheehos started to gather info about the swap but i don't think it's actually complete yet
https://acurazine.com/forums/1g-cl-diy-faq-74/center-console-97-98-99-a-703873/
Originally Posted by dragon084
all you need to do is buy the console.
you need the whole assembly though.
i however, did not do the swap.
#158
i didn't spend a lot of time, i just remebered it from the time that Cheehos started his thread, thought i'd share it with you guys especially the link to the thread and the member Cheehos to see the replies from Greg that he wrote on Cheehos's public profile. If he did have the swap done, then atleast my info plus links will keep him from asking Greg (dragon084) the same questions that Cheehos did
btw when did i say that he didn't have it done? i just said what greg had replied to Cheehos with, and i wasn't proving it one way or another all i said is that's what i "thought"
#159
Boats and Hoes!
Hmm, well I just wanted to know for sure if someone has, and if so, if there was much modification that needed done to fit it. It probly won't be easy to find a 98-99 manual trans console anyway, but if I did come across one for a good price I would buy it if it is interchangeable with mine. I'm a fan of the wood trim and I think it looks so much cleaner and classier than the 97's
#160
(Mid-Atlantic)
(Mid-Atlantic)
shouldn't matter if it's manual or not, the console only has one square opening
