98 Acura CL Retro fit 2008 TL Engine & Tranny
Old 10-19-2010, 06:44 PM
4th Gear
Red CL's Avatar
I have 1998 Acura CL 3.0, I also have a 2008 TL 3.5 Engine & Tranny that I would like to retro fit into the 98 CL. Was wondering if anyone here has ever done this retro fit and if it can be done?
Old 10-19-2010, 06:50 PM
v-takyo!!'s Avatar
how much mula do you have cause thats gonna be a hell of a lot of money anything is possible with the right amount of cash
Old 10-19-2010, 06:53 PM
4th Gear
Red CL's Avatar
Money is not the problem, just wanted to know if it can be done
Old 10-19-2010, 08:59 PM
asianspec's Avatar
Received 1,097 Likes on 831 Posts
search for cocoa. he did the J32 swap with an odyssey block and RL cams which made it 3.5. Its a very tight fit in the engine bay which he does have issues closing the hood, so he bent it. wiring is going to be a mess. and if you are paying somebody its expensive. he also used a 6speed CL-S tranny
Old 10-19-2010, 09:04 PM
v-takyo!!'s Avatar
abything can be done with the right amount of cash i was just letting you know cause if you do try it itll cost you a hefty amount
Old 10-19-2010, 09:42 PM
First EVER K24 Turbo CL
starboy2nv's Avatar
if your asking and saying money isnt a problem, then your not doing it.
/thread
Old 10-19-2010, 09:54 PM
CL SLeePeR's Avatar
Possible? Yes, time and money would be your expense. The j35a5 is shorter in length and weighs less than the 3.2's and older 3.5's out of the older J-series. Your biggest obstacle would be wiring it all up.
Old 10-19-2010, 11:30 PM
P0401's Avatar
I guess to answer your questions, yes it can be done and yes it has been done
Old 10-22-2010, 08:17 AM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,408 Likes on 3,020 Posts
It can be done, I'd love to see it done, do eet
Old 10-26-2010, 03:10 PM
Skuuuurrrrrt!
GhettoNinja06's Avatar
/thread
lol, same thing I was thinking..
Old 02-03-2016, 08:27 AM
Mike Retherford's Avatar
I need a new OEM 1998 Acura RL 3.5 L Engine!
Old 02-03-2016, 02:41 PM
Ya, I am not sure if I want to change the rear main seal, the timing belt and water pump or yank it all out and rebuild everything because I know the intake manifold has a lot of carbon build up but still runs good, just leaks oil. I would really like someone to rebuild the engine and trans with all Acura replacement parts but it is very hard to trust anyone let alone get ripped off on the money end of it as well. Wish I knew what to do? The rest of the car on a scale of 10 is 8, pushing 9..Sweet ride!!
Gabru678
04-24-2019 02:36 PM
drone619
01-26-2016 07:09 PM
nanos
11-12-2015 08:41 PM
Nitin
09-30-2015 08:22 PM
Glorygang600
09-05-2015 01:17 AM
Quick Reply: 98 Acura CL Retro fit 2008 TL Engine & Tranny
