engine splash guard front under cover for 2005 acura mdx
I am trying to locate an engine splash guard front under cover. The original part is similar to what I have located online but not exact. I am not sure if other will fit since they are not exactly like the original. Do you any advice?
Finding a new one may be difficult. But check out AH Parts. They're a Honda/Acura salvage facility in CA. I've had good luck locating decent quality used parts there. If it's not listed, just send them an email.
https://ahparts.com/
teh CL (01-15-2017)
Considering this is RL forum a post in MDX forum might be better suited for your question. I had no issue finding new parts even for my older cars, the problem you might find is shipping costs will be high due to size of the piece.
Considering there was a ton of these things produced I find it hard to believe a used one is not obtainable in a breaker yard near you.. Search using car-part.com if you want to go the used route. Or I have found that rock auto sells these as well fit is spot on but density of the pieces is not the same.
Moved to 2G MDX.
sockr1
315
06-03-2021 03:46 PM
a4syth
02-08-2017 02:57 PM
YourNorthSid3r
New Member Introductions
12-23-2016 07:41 AM
