Adding license plate mounted LED tied into reverse light
Old 01-24-2017, 06:44 PM
2011MDXGrey's Avatar
I'm looking to add a license plate mounted to add additional light for the backup camera. I'm wanting to know how to tie into reverse lights?
Old 01-24-2017, 06:58 PM
Received 8,575 Likes on 6,626 Posts
you'll have to pull off the license plate trim to run the wires you can run them along the same grommet used to weather seal the cable for the backup cam. Then just tape inot the two wires that turn on the reverse lights..
Note though: I did this and it added a TON of glare to the camera rendering it useless. If you do do it, make sure the LEDs are in the frame along the bottom of the plate and not on top closest to the camera.
I was the VLED LPF license plate frame.
Old 01-27-2017, 09:00 AM
2006 NBP TL MT6/ 02TL-S
AlanW's Avatar
I've noticed something about the backup lights. I've converted to brighter LED lights like many. When there is little or nothing behind you for the light to shine on, the backup lights don't seem very bright. But if there is actually something back there, it lights it up pretty good.
Old 01-27-2017, 09:43 AM
What kind of LEDs did you get. Mskensure they have LEDs on the side that fire into the reflector and not just straight out
Old 02-01-2017, 08:42 AM
TrackDayRdr's Avatar
That's not the confidence I want when backing up in the dark. The thud of something hitting my bumper just as it comes into camera view. A foot on the brake does a lot more than even improved reverse LED bulbs will accomplish.
Old 02-01-2017, 08:57 AM
Received 16,260 Likes on 11,971 Posts
you know what would be cool!?
if some one added an infrared lighting to either the camera, or upgrade the camera to one with infrared lighting. THAT would solve the problem
wait, what do home security cameras use? that's infrared right??? but it will only light up heat sources...>??
okay, probably not a good idea
Old 02-01-2017, 09:10 AM
While we're at it, know what else would be cool? James Bond style gadgets.
justnspace (02-01-2017)
Old 02-01-2017, 09:12 AM
inspector gadget....gadgets!!
Old 02-02-2017, 08:41 AM
AlanW's Avatar
James Bond would be a 50 cal Gatling gun mounted in the back behind the power lift gate....just the thing for those annoying tailgaters.
Old 02-02-2017, 08:55 AM
Or a pop-up snow plow for those pesky highway protesters.
Old 02-02-2017, 10:58 AM
AlanW's Avatar
Why not both? I mean, we're James Fucking Bond, right?
And if there is front radar braking on vehicles, it's just a short step to radar guided front launch missiles
sockr1
315
06-03-2021 03:46 PM
thisaznboi88
03-19-2017 08:45 PM
DerrickW
24
03-08-2017 01:42 AM
brouse
01-13-2017 12:55 PM
Killah_Cam92
12-27-2016 12:13 PM
Quick Reply: Adding license plate mounted LED tied into reverse light
