2007 MDX - Two windows stopped working, replaced parts, still not working
Old 02-15-2017, 06:17 PM
sseiyah's Avatar
Unhappy 2007 MDX - Two windows stopped working, replaced parts, still not working
2007 MDX
Intermittently random windows stopped working, however as of a few weeks ago the drivers front and drivers rear no longer roll down from the driver door switch. The passenger side front and rear are fine. The driver rear works fine with its own switch. Switching the child lock on the master window switch does disable the driver rear window when pressed so there seems to be some communication occurring between the master and slave switch.
So far in this order:
1. Verified all 4 window fuses in the driver kickpanel were good.
2. Unplugged Battery overnight
3. Reset windows using the full up for 3 seconds then full down for 3 second method
4. Replaced Window Switch (35750-STX-A01ZA) with new OEM part from Dealer
5. Replaced Driver Door Module (38860-STX-A01) with new OEM part from Dealer
Whats next? I really have been trying to avoid taking it to the dealer however I've spent a couple hundred bucks on parts and not getting anywhere.
Old 02-15-2017, 07:04 PM
sseiyah's Avatar
So I did some more research, found this just now, hopefully this is the problem:
Old 02-15-2017, 08:21 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
You didn´t see my DIY about it? https://acurazine.com/forums/1g-2g-m...arness-939145/
Old 02-16-2017, 07:45 PM
sseiyah's Avatar
Originally Posted by Skirmich
Yes, I found another thread pointing to this, thanks for the write-up
I can confirm this fixed the window problem today finally!
Auto-Up/Auto-Down on drivers window does not work even after rolling it all the way down and then all the way up and holding for 2 seconds, not sure how to fix that.
Old 02-17-2017, 12:40 AM
Skirmich's Avatar
Thank You! and Congrats on Fixing it!
Sometimes they do not re-learn with the 2 second trick.. Give it sometime for it to learn it manually and they should work, They always do that if you disconnect the battery.
Old 05-15-2018, 12:37 AM
BlacknBlueJ32's Avatar
Pretty random but how did you replace the master window switch? I took the door panel off and cannot figure out how to get the master switch assembly off. Cant find any write ups on it either. RhThan
