2007 MDX turn signal flasher
hey guys, so i just changed my signal bulbs to some led ones. The point was i was trying to location the turn signal flasher so i could change it to the led resister kit to avoid the hyperflash but i couldnt find it. Do you guys happen to know where it is?
Merry Christmas
Man do not complicate it, Just get the Inline Resistors from Autozone and that´s it! I did both of my rear Turn Signal Lights with some Philips LEDs and I got the hyper flash.. Added the Resistors and problem solved!
I haven´t found suitable Yellow LEDs for the Front Turn Signals so I kept those stock.
Merry Christmas!
Merry Christmas!
Merry Christmas!
Merry Christmas!
Merry Christmas!
Merry Christmas!
This way is more efficient, and it is much safer compared to inline resistors(No Heat).
Marry Christmas everyone
Efficient? blinkers only come up so often that changing them to LEDs is not because of Energy Savings but because of the Quick On/Off dynamic.. My Philips LEDs on the rears even with the Resistors have this and they illuminate way more than the stock halogen light and its a Bright Intense RED not the washed out Halogen + Red Screen combo.
To OP you can known the polarity with a small Volt/Meter I cannot remember which wire is what but it doesn't really matter as the Resistor is just a Load for the Relay.. It wont make a difference if the polarity is reversed.
LED flasher > in line resistors, resistors heat up and depending where they are mounted, it can be problematic.
The flasher is definitely is the right course of action.
when I will get TL, I will do little DIY how to convert Oem flasher to LED compatible one... Because IT IS A RIGHT WAY....
Skirmich, you know what sucks.. when cheap Chinese LED loses contact or just fails and you're using LED resistor there will be no warning... With proper LED flasher you'll get hyper-flash.
There's more than one way to skin a cat Skirmich to each their own I guess
I am not sure, but you can open original one, remove metal pin/resistor and solder this little guy,: https://www.amazon.com/NTE-Electronics-2WD12-Flameproof-Resistance/dp/B007Z7PCPO/ref=sr_1_2?ie=UTF8&qid=1482812296&sr=8-2&keywords=2W+0.12-Ohm
Its like, 5 min job... Works with leds or incandescent or you can have mix of both.
So same as this? https://acurazine.com/forums/third-g...istors-815219/
Cool to hear that works for the MDX TOO !
Yes, sir. Same thing LOL
No need for DIY now LOL
Soooooo In order to remove the Inline Load Resistors I have to add a Resistor into the Relay?
Yeahhh that is no way in hell easier than adding Inline Load Resistors, Since mine has been working so well all these years and there is no plug and play option Id stick with the good old fashioned Inline Load Resistors.
I thought you guys were recommending the Relay Option because it was an Easy Plug and Play ready to fit in LED Relay...
Hacking into the OEM Relay and Soldering is not DIYer friendly at all..
I went on quickly to see how the Inline Resistor has been holding with +8 months of use and its fine.. The ceramic doesn´t look cracked or feel brittle to the touch, No melted parts not even the tape, and the rear of the tailgate is immaculate aside from the Dirt of course. Its still blinking fine.
Intense Red with Fast ON/OFF switching from the Philips LEDs 7443 Bulbs (MDX uses 7440, but 7443 works fine)
https://www.amazon.com/Philips-7440-...00P2D3W0A?th=1
This particular characteristic of the MDX has me scratching my head at Honda. They made almost the whole tail light out of LED's, yet they choose to make the turn signal halogen rather than have the led's flash?
Thank you Skirmich, to you as well and a happy new year!
